    2019 update 1 crash
    Scheduled Pinned Locked Moved LayOut Bug Reporting
    layout
    6 Posts 2 Posters 13.8k Views 2 Watching
      congellous
      I have a 7 page DWG that I have never been able to export as a DWG and this update now adds crashing instead of export.
      Keep checking for one day it might work.
      I have tried many different options and DWG release or DXF to no avail.
      I currently have to send the "model space" sketch-up model as a 3D dwg export along with the PDF's
      to other consultants that is not ideal, a larger more co-ordinated job would be difficult.
      I have added JPG versions if anyone can see what the problem might be
        Unfortunately the JPG images are not likely to provide enough info to identify the source of the problem. Can you share the LayOut file?
        When LayOut crashes, do you get a Bug Splat? If so, are you sending them or just closing the window? If you are sending them, are you including contact information?
        What operating system are you using? (You've never completed your profile.) If you are using Windows, did you install SketchUp by right clicking on the installer file to choose Run as administrator?
        Can you successfully export any LO file to DWG?
        I've seen reports where something like a logo image has caused problems with DWG/DXF exports. I've also seen cases where certain components from the 3D Warehouse added to the SketchUp model caused LayOut to crash. You could start removing things and see if you get a change in behavior with the export.
          congellous
          I just removed the Red stamp saying for approval and it seems to have worked !?
          I can export some files to DWG
          Windows 10
          I just updated sketchup from web site ?
          Sorry, can't upload Layout file
            Well, that was easy. What kind of entity is that stamp? An image?
            @congellous said:
            Windows 10
            Please add that info to your profile.
              congellous
              no it was just impact font saying for approval in red outline
              it was rotated though ??
                Interesting.
