    MSPysics Hinge problem
    4 Posts 3 Posters 6.5k Views 3 Watching
      Chambry
      Hello everyone
      I have a problem with the joint hinge, the stiffness of the hinge is set to 1.000 however the object attached to it moves in the Z-axis as if there was a huge gravity. When the object does not move any more it has returned well in the axis of the hinge.
      In advance Thank you for your answers Eric
      Problem Hinge
        Anton_S
        Set the mass of the body attached to the hinge to 1.0. If the hinge has a parent body, make the mass of the parent body not too different from the mass of the attached body. Joint stiffness is a problem in MSPhysics at the moment.
        • ecatiE Offline
          ecati
          Set values ​​like this and try again.
            Chambry
            Hello Anton and Ecati
            Thank you for your answers but I still have problems.
            I hope one day to do you a favor
            Greetings and thanks to you both
