    πŸ”Œ Easy Offset | Offset selected faces in SketchUp in positive and negative offsets. Download
    LAYOUT EXPORT TO PDF BUG
    Scheduled Pinned Locked Moved LayOut Bug Reporting
    layout
    3 Posts 3 Posters 23.7k Views 3 Watching
      andreylima813
      WHEN I EXPORT FROM LAYOUT TO PDF, THERE WILL ME SOME BLACK RECTANGLES COVERING SOME AREAS.
      LAYOUT
      PDF
        Can you share the LayOut file so we can have a look and try to help you solve the problem? Are you using LayOut 2017?
        • FlatchoumF Offline
          Flatchoum
          Hi, I used to have the same issur running the plugin "advanced camera tools"
          You can solve it in going to your plugin and click (on the scene in sketchup):
          "clear the aspect ratio and returns to the default camera"
