    Shape Bender Plugin - SU 2019
    extensions
    2 Posts 1 Posters 14.3k Views 1 Watching
    • B
      botzinho
      Good night. I'm having trouble with the Shape Bender plugin in SketchUp 2019. It does not show the start button and the end button. Anyone with the same problem as me? 😕
      I have not found an update for this plugin. 😐
      • B
        botzinho
        I find an fix:
        https://forums.sketchup.com/t/shape-bender-and-su2019/89078/2
        "If the file …/Plugins/clf_shape_bender/clf_shape_bender_data.rb is edited with a plain text editor there are four lines to tweak…
        Lines# 290, 291 and 302, 303
        At the end of those lines add .position [so that the vertex position [i.e. a point] is used instead of the vertex itself]
        So for example:
        start_label = Sketchup.active_model.entities.add_text “Start”, @line_endverts[0]
        becomes
        start_label = Sketchup.active_model.entities.add_text “Start”, @line_endverts[0].position"
        I tried and it worked perfectly. 😎
