    πŸ›£οΈ Road Profile Builder | Generate roads, curbs and pavements easily Download
    MS Physics and SU 2019
    15 Posts 15 Posters 28.8k Views 15 Watching
    • PixeroP Offline
      Pixero
      Does MS Physics work with SU 2019?
      I get error messages when loading it.
        samnorth
        I got errors at startup too. I disabled it for now as i don't use it very often.
          Anton_S
          No it doesn't work with 2019 as of yet.
          • E Offline
            Eric Shively
            I don't get error messages, it just doesn't show up when I download it. πŸ˜•
              alvin meza
              lastimosamente no corre en 2019 es una pena considerando el potencial del pluguin esta revisando continuamente para ver si se resuelve el problema...
                LEGOsketcher
                Only works for SU 2017. Is there an update in scope or do you know of a similar plugin to drop stuff at random in a basket for example? Really hope for a 2019 update - such an awesome plugin.
                • V Offline
                  veyslk
                  When will MSPhysics SU2019 work. Year is over.
                    Sisu
                    Has there been any movement on this? Would love to use it in SU2020.
                    • N Offline
                      nesztler
                      Hi All,
                      MSPhysics works well for me !
                      For that, you must put the MSPhysics directory and MSphysic.rb directly in the library directory of SKetchup 2019. Futhermore, you must add AMS_library 3.5.0 + with the extension manager.
                      if you have any difficulties, ask to me and i answer you
                      Best regard
                      Thierry
                        dandrak37
                        @nesztler said:
                        Hi All,
                        Best regard
                        Thierry
                        Hi Thierry,
                        Do we need to install first the library? or it doesn't matter the order of installation.
                        Thanks in advance,
                        Jose Castellot
                          carsanl5
                          @nesztler said:
                          Hi All,
                          Best regard
                          Thierry
                          Hey, could you let me know the exact route where you paste it ?i'm pretty nooby at this, also, do you copy the MSPhysics.rbx ?
                          thanks in advance!
                            asd123dsa
                            I can't load
                            • K Offline
                              KadirSket
                              2020 ?
                                Jiivandev
                                Hello
                                I am new on MSPhisics and still using SU 2019. Already tryed to install first AMS Library and MSPhisics by using "Install extension" and and locate the file .rbz in the plugin Folder.
                                The plugin after installation seems are installed but alway this message:
                                Error Loading File C:/Users/Giuseppe.-------/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/MSPhysics/main_entry.rb
                                Error: #<IOError: The required, staged c extension file, "C:/Users/Giuseppe.-------/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/MSPhysics/libraries/stage/win64/2.5/msp_lib.so", is missing!>
                                C:/Users/Giuseppe.---------/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/ams_Lib/extension_manager.rb:204:in block in require_all' C:/Users/Giuseppe.-------/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/ams_Lib/extension_manager.rb:201:in each'
                                C:/Users/Giuseppe.--------/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/ams_Lib/extension_manager.rb:201:in require_all' C:/Users/Giuseppe.--------/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/MSPhysics/main.rb:70:in <top (required)>'
                                C:/Program Files/SketchUp/SketchUp 2019/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:59:in require' C:/Program Files/SketchUp/SketchUp 2019/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:59:in require'
                                C:/Users/Giuseppe.--------/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/MSPhysics/main_entry.rb:15:in <top (required)>' C:/Program Files/SketchUp/SketchUp 2019/Tools/extensions.rb:197:in require'
                                C:/Program Files/SketchUp/SketchUp 2019/Tools/extensions.rb:197:in load' C:/Users/Giuseppe.-------------/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/MSPhysics.rb:21:in register_extension'
                                C:/Users/Giuseppe.---------/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/MSPhysics.rb:21:in <module:MSPhysics>' C:/Users/Giuseppe.------/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/MSPhysics.rb:5:in <top (required)>'.
                                Any one have suggestions ?
                                What's going one ?
                                Thank's
                                Giuseppe
                                  If you read through this thread you will see that the author has indicated it doesn't work in SketchUp 2019. See:
                                  https://sketchucation.com/forums/viewtopic.php?f=61&p=669802#p646407
                                  As of this date it has not been updated to work with SketchUp 2019 or newer.
