    MS Physics and SU 2019
    15 Posts 15 Posters 30.9k Views 15 Watching
      samnorth
      I got errors at startup too. I disabled it for now as i don't use it very often.
        Anton_S
        @pixero said:
        Does MS Physics work with SU 2019?
        I get error messages when loading it.
        No it doesn't work with 2019 as of yet.
        • E Offline
          Eric Shively
          I don't get error messages, it just doesn't show up when I download it. πŸ˜•
            alvin meza
            lastimosamente no corre en 2019 es una pena considerando el potencial del pluguin esta revisando continuamente para ver si se resuelve el problema...
              LEGOsketcher
              Only works for SU 2017. Is there an update in scope or do you know of a similar plugin to drop stuff at random in a basket for example? Really hope for a 2019 update - such an awesome plugin.
              • V Offline
                veyslk
                When will MSPhysics SU2019 work. Year is over.
                  Sisu
                  Has there been any movement on this? Would love to use it in SU2020.
                  • N Offline
                    nesztler
                    Hi All,
                    MSPhysics works well for me !
                    For that, you must put the MSPhysics directory and MSphysic.rb directly in the library directory of SKetchup 2019. Futhermore, you must add AMS_library 3.5.0 + with the extension manager.
                    if you have any difficulties, ask to me and i answer you
                    Best regard
                    Thierry
                      dandrak37
                      @nesztler said:
                      Hi All,
                      Best regard
                      Thierry
                      Hi Thierry,
                      Do we need to install first the library? or it doesn't matter the order of installation.
                      Thanks in advance,
                      Jose Castellot
                        carsanl5
                        @nesztler said:
                        Hi All,
                        Best regard
                        Thierry
                        Hey, could you let me know the exact route where you paste it ?i'm pretty nooby at this, also, do you copy the MSPhysics.rbx ?
                        thanks in advance!
                          asd123dsa
                          I can't load
                            KadirSket
                            2020 ?
                              Jiivandev
                              Hello
                              I am new on MSPhisics and still using SU 2019. Already tryed to install first AMS Library and MSPhisics by using "Install extension" and and locate the file .rbz in the plugin Folder.
                              The plugin after installation seems are installed but alway this message:
                              Error Loading File C:/Users/Giuseppe.-------/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/MSPhysics/main_entry.rb
                              Error: #<IOError: The required, staged c extension file, "C:/Users/Giuseppe.-------/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/MSPhysics/libraries/stage/win64/2.5/msp_lib.so", is missing!>
                              C:/Users/Giuseppe.---------/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/ams_Lib/extension_manager.rb:204:in block in require_all' C:/Users/Giuseppe.-------/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/ams_Lib/extension_manager.rb:201:in each'
                              C:/Users/Giuseppe.--------/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/ams_Lib/extension_manager.rb:201:in require_all' C:/Users/Giuseppe.--------/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/MSPhysics/main.rb:70:in <top (required)>'
                              C:/Program Files/SketchUp/SketchUp 2019/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:59:in require' C:/Program Files/SketchUp/SketchUp 2019/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:59:in require'
                              C:/Users/Giuseppe.--------/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/MSPhysics/main_entry.rb:15:in <top (required)>' C:/Program Files/SketchUp/SketchUp 2019/Tools/extensions.rb:197:in require'
                              C:/Program Files/SketchUp/SketchUp 2019/Tools/extensions.rb:197:in load' C:/Users/Giuseppe.-------------/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/MSPhysics.rb:21:in register_extension'
                              C:/Users/Giuseppe.---------/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/MSPhysics.rb:21:in <module:MSPhysics>' C:/Users/Giuseppe.------/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/MSPhysics.rb:5:in <top (required)>'.
                              Any one have suggestions ?
                              What's going one ?
                              Thank's
                              Giuseppe
                                If you read through this thread you will see that the author has indicated it doesn't work in SketchUp 2019. See:
                                https://sketchucation.com/forums/viewtopic.php?f=61&p=669802#p646407
                                As of this date it has not been updated to work with SketchUp 2019 or newer.
