Replacing same groups by component
Hi sketchucatheads
I messed up, starting with my first model I made groups not components, and now I have to change all this groups the same way......
Is there a possibility to replace this groups by a component (with same dimensions as groups) in order to change all structures by one action??? Or can I select all the same groups by one action and turn it into a component???Thanks for helping!!!!!!
Jo -
I believe you want ThomThom's plugin "Groups to Components" Select one of the groups and in the Contextual menu you can choose the command "Group Copies / Select All"(or another selection choice). Once they are selected choose "Group Copies / Convert to Components". Each group has to be un-edited from the others. Perhaps someone has a one-time script for this, IDK.
After converting all groups to components, you can replace them all by a single one using component replacer plugin, also from thomthom
Register LoginAdvertisement
