    Medeek Electrical
    205 Posts 6 Posters 226.0k Views 5 Watching
      db11
      Nathaniel β€”
      Any thought of creating an auto-generating mode for the wiring module?
      I imagine it working something like this:
      1. Select start device (set startType)
      2. Select end device (set endType)
      3. Resolve path type:
      • outlet to outlet
      • hot wire to switch box/junction box
      • switch to fixture
      • fixture to fixture
      • etc..
      1. lookup presets for device heights / wire path height / curve radius etc.
      2. create wire path based on presets / rules
      3. generate wire geometry
      (The logic would be a little more complex for resolving 3-way switch to fixture paths, but doable)
      Of course the resulting paths would be editable using the same mode as you've shown.
      A similar approach could then be used for the HVAC module, using the appropriate rules and presets (including room volumes, desired CFM, ACH etc) to set duct sizes per trunk/branch etc.
      Not to add to your substantial to-do list(!), but the value of auto-generated wiring / plumbing / HVAC runs would be huge. This function doesn't have to be perfect or encompass every possible use case β€” even if the auto generating only achieves 60% of the end result and the rest need to be edited, it's still a huge reduction of modelling time/effort.
      Interested in your thoughts on this.
      • medeekM Offline
        medeek
        @db11
        In theory what you have described seems like a workable solution and possibly a valuable feature that could be added to the plugin.
        However, there are a few difficulties with implementing this in practice. Typically two devices are separated from each other (possibly in different walls) in the X-Y plane (let's disregard the Z axis for now). The simplest path between any two devices based on their location and rotation would be one of three cases: straight line, L-shaped path, S-shaped path (this assumes orthogonal walls of course).
        It would be easy enough to enable some sort of logic to determine which of these three options is the correct path (path finding logic) between any two devices. Adding the height difference further complicates things but that could also be factored in and programmed.
        The problem I see is that except for the simplest of cases the path determined by the algorithm will rarely coincide with what you the designer or electrical contractor would actually do in real life. I'm going to say 95% of the time the path will need significant adjustment so that the wires land properly (centered) inside of the walls.
        The user would probably find this feature more frustrating than useful, but I could be wrong.
        P.S.
        Now, if the algorithm was even smarter and could somehow take into account the walls, ceilings and floors within the model and also use this information in generating the path then I could see the light at the end of the tunnel on this one. I will have to give this some more thought...
        Nathaniel P. Wilkerson PE
        Medeek Engineering Inc
        design.medeek.com
        • medeekM Offline
          medeek
          Version 1.2.2 - 10.16.2020
          • Added a "2d Symbols Only" parameter into the General tab of the Global Settings.
          • Enabled the "2d Symbols Only" mode for the following electrical elements: Outlets, Switches.
          http://design.medeek.com/resources/electricalplugin/images/elec_su214_800.jpg
          http://design.medeek.com/resources/electricalplugin/images/elec_su213_800.jpg
          Yet another update per customer requests. A number of users only want to use the plugin to show the 2D electrical symbols rather than drawing the 3D electrical components (and the symbols). (Technically one could achieve pretty much the same result by turning off the electrical rough and finish layers.)
          The new 2D symbols only mode will allow this mode wherein only the 2D symbols are drawn. Note, that I have only enabled this feature for outlets and switches thus far and I will need to extend that functionality to all other electrical elements (ie. fans, data outlets, floor outlets, panels etc...)
          The nice thing about this bimodal system is that all of the regular data is being stored for each electrical component in the model (attribute library) so one can switch between modes mid-stream without any problems if necessary.
          design.medeek.com
          • medeekM Offline
            medeek
            Similar to the estimator found in the Wall plugin the user will be able to select "All" or a selection of assemblies to run the estimator on:
            https://aws1.discourse-cdn.com/sketchup/original/3X/c/1/c171afbeaf02208ed12b9aca04c89d1fceaaa8dc.jpeg
            The non-Medeek wall and roof assemblies will also be selectable since the Electrical plugin also works with non-Medeek walls, roofs etc...
            I don't feel like it is necessary to break the listings into the assemblies they are part of however I will include a column in each table which lists the main assembly the electrical component is found in, this should prove useful to some.
            There are a lot of little details with regards to different electrical components (ie. outlets, switches, panels etc...) Each type of electrical component has unique characteristics, all of this data needs to be output by the Electrical Estimator, it will probably take me a few days to assemble this new module.
            Once it is complete it will make this plugin a much more useful tool.
            P.S. I think it would be also quite useful at some point to incorporate a price database that works with the estimating module. This separate database would be referenced to determine the price, vendor etc... for a given electrical component. Additionally, the list of materials could then be conveniently broken into separate purchase orders for each vendor. I'm probably getting a bit ahead of myself here but with the ability to program just about anything with the API and the Ruby back end its conceivable that one could generate PO's that could then easily be imported into Quickbooks or any other accounting software. I've done a bit of Quickbooks API programming in the past where I integrated my own customer billing system and expense database with the software, its really not that hard to do.
            When I ran my web hosting company back in the early 2000's I got really sick of having to manually enter in customer orders and business expenses into Quickbooks, the problem was my billing system and Quickbooks (my accounting system) were completely two different ecosystems. I would usually have to devote one entire day out of the month for this tedious task. I finally got smart one day and decided it would be really nice if I could somehow automate this process. After about two days of programming I had fully automated the manual entry problem and set it up as Chron job that would run nightly, it would even shoot me out an automatic email every morning letting me know how the process went and if there were any issues.
            "Laziness is the mother of invention"
            design.medeek.com
            • medeekM Offline
              medeek
              First look at the CSV output (imported into Excel) for the Electrical Estimator:
              https://aws1.discourse-cdn.com/sketchup/original/3X/6/2/62ac09ba75bec7d9aa486251b2ca3269a996b7e0.jpeg
              *Note, the additional formatting (column spacing, bold, underline) is done in Excel after the import.
              Also note that I have the total lengths tallied for each wire type.
              design.medeek.com
              • medeekM Offline
                medeek
                Version 1.2.3 - 10.20.2020
                • Created the initial framework of the Medeek Electrical Estimating Module.
                • Added wiring to the Medeek Electrical Estimator.
                • Added the ability to export data from the Medeek Electrical Estimator in CSV format.
                http://design.medeek.com/resources/electricalplugin/images/elec_su218_800.jpg
                I also need to figure out what sort of CSI numbering to assign electrical components.
                design.medeek.com
                • medeekM Offline
                  medeek
                  In the example shown below I've color coded my network cables based on whether they service the first or second floor of the building. The red cable is the designated switch-to-switch or router-switch cabling:
                  https://aws1.discourse-cdn.com/sketchup/original/3X/6/6/665eedd1292bc34a068a2c095b4261243ddac3f5.jpeg
                  https://aws1.discourse-cdn.com/sketchup/original/3X/e/1/e1d6a067c4519830c179df86c47708efd1f8aa6a.jpeg
                  https://aws1.discourse-cdn.com/sketchup/original/3X/f/8/f840f66df1be4a01487a33993c1e186b6c7df71d.jpeg
                  Note that the totals allows me to determine my cable amounts for each floor. I'm also able to determine that each cable run does not exceed a max. length.
                  View model here:
                  3D Warehouse
                  3D Warehouse is a website of searchable, pre-made 3D models that works seamlessly with SketchUp.
                  (3dwarehouse.sketchup.com)
                  Once I created all of my cable paths I dropped them onto a separate layer so I could easily hide them (and keep them around for future use if needed) once my wires were created.
                  design.medeek.com
                  • medeekM Offline
                    medeek
                    Version 1.2.4 - 10.22.2020
                    • Added outlets and switches to the Medeek Electrical Estimator.
                    http://design.medeek.com/resources/electricalplugin/images/elec_su222_800.jpg
                    design.medeek.com
                    • medeekM Offline
                      medeek
                      First look at UK electrical outlets and switches in the electrical estimator:
                      https://aws1.discourse-cdn.com/sketchup/original/3X/a/c/ac1a2b3b49998e5b3bf7baa1544b17dd9bbe82db.jpeg
                      design.medeek.com
                      • medeekM Offline
                        medeek
                        Version 1.2.5 - 11.12.2020
                        • Added data (low voltage) outlets, lights, panels, UK outlets, and UK switches to the Medeek Electrical Estimator.
                        http://design.medeek.com/resources/electricalplugin/images/elec_su224_800.jpg
                        The following (six) electrical elements still need to be added into the Electrical Estimator:
                        Safety Devices, Heaters, Vents, Floor Outlets, Low Voltage Panels, Misc. Fixtures
                        design.medeek.com
                        • medeekM Offline
                          medeek
                          Version 1.2.6- 11.13.2020
                          • Added Safety Devices, Heaters, Vents, Floor Outlets, Low Voltage Panels and Misc. Fixtures to the Medeek Electrical Estimator.
                          The Electrical Estimator is now complete. I still need to change up the CSI numbers for the various components but for now I've just used my own default numbering system. I will need to get with some electrical contractors on what are the appropriate numbers to use.
                          I will now turn my attention to more pressing matters involving the Truss plugin.
                          design.medeek.com
                          • medeekM Offline
                            medeek
                            Version 1.2.7 - 02.13.2021
                            • Enabled the ability to draw outlets and switches with Medeek Polyline Stemwall assemblies.
                            http://design.medeek.com/resources/foundationplugin/images/foundation_su74_800.jpg
                            design.medeek.com
                            • medeekM Offline
                              medeek
                              Version 1.2.7b - 02.13.2021
                              • Enabled the ability to draw UK outlets and switches with Medeek Polyline Stemwall assemblies.
                              http://design.medeek.com/resources/foundationplugin/images/foundation_su75_800.jpg
                              design.medeek.com
                              • medeekM Offline
                                medeek
                                Version 1.2.8 - 04.30.2021
                                • Added optional metadata parameters for UK outlets and switches: description, circuit.
                                • Added a circuit callout parameter in the General tab of the global settings.
                                • Added a 5th dimensioning layer specifically for circuit callouts in the Layers tab of the Global Settings.
                                • Enabled circuit callouts for the following fixtures: Switches, Outlets, UK Switches and UK Outlets.
                                http://design.medeek.com/resources/electricalplugin/images/elec_su225_800.jpg
                                http://design.medeek.com/resources/electricalplugin/images/elec_su226_800.jpg
                                design.medeek.com
                                • medeekM Offline
                                  medeek
                                  Version 1.2.9 - 05.30.2021
                                  • Added an option for vertically offsetting text and symbols within the General tab of the Global Settings.
                                  • Annotation text and symbols for outlets, switches, UK outlets and UK switches can be vertically offset a custom amount from the bottom of the wall.
                                  http://design.medeek.com/resources/electricalplugin/images/elec_su227_800.jpg
                                  http://design.medeek.com/resources/electricalplugin/images/elec_su228_800.jpg
                                  The default placement was at the bottom of the framed wall, and the default offsets still are zero unless otherwise specified differently. However in most situations this resulted in Z-fighting with the subfloor and if a finished floor was modeled then the symbols and text would be buried within the finished floor or carpet (not visible). This option allows the user to customize the vertical placement to suit their particular needs.
                                  This update was per customer request.
                                  design.medeek.com
                                  • medeekM Offline
                                    medeek
                                    Version 1.3.0 - 06.01.2021
                                    • Added four additional parameters to the "User Interface" section of the General tab of the global settings. This allows the customization (colors) of the HTML menus and buttons.
                                    http://design.medeek.com/resources/electricalplugin/images/elec_su229_800.jpg
                                    design.medeek.com
                                    • medeekM Offline
                                      medeek
                                      Version 1.3.1 - 06.16.2021
                                      • Updated the wiring module/algorithm to improve performance and overall robustness.
                                      design.medeek.com
                                      • medeekM Offline
                                        medeek
                                        Version 1.3.2 - 07.11.2021
                                        • Enabled subscription and permanent licensing.
                                        • The License tab of the Global Settings now displays the license type.
                                        design.medeek.com
                                        • medeekM Offline
                                          medeek
                                          Version 1.3.3 - 01.11.2023
                                          • Enabled layer control integration with the Medeek Project extension.
                                          design.medeek.com
                                          • medeekM Offline
                                            medeek
                                            Version 1.3.4 - 06.13.2023
                                            • Enabled switches, outlets and lights to be inserted into "component" walls.
                                            Previously electrical fixtures could only be inserted into walls that were "groups", with this update the wall assemblies can be either groups or components.
                                            This update per customer request.
                                            P.S.
                                            I will still need to update the other misc. electrical fixtures (ie. panels, low voltage, safety, heaters, vents, low voltage panels etc...)
                                            design.medeek.com
                                            • 7
                                            • 8
                                            • 9
                                            • 10
                                            • 11
                                            • 9 / 11
