    Medeek Electrical
    205 Posts 6 Posters 268.4k Views 5 Watching
    • medeekM Offline
      medeek
      Version 1.2.5 - 11.12.2020
      • Added data (low voltage) outlets, lights, panels, UK outlets, and UK switches to the Medeek Electrical Estimator.
      http://design.medeek.com/resources/electricalplugin/images/elec_su224_800.jpg
      The following (six) electrical elements still need to be added into the Electrical Estimator:
      Safety Devices, Heaters, Vents, Floor Outlets, Low Voltage Panels, Misc. Fixtures
      Nathaniel P. Wilkerson PE
      Medeek Engineering Inc
      design.medeek.com
      • medeekM Offline
        medeek
        Version 1.2.6- 11.13.2020
        • Added Safety Devices, Heaters, Vents, Floor Outlets, Low Voltage Panels and Misc. Fixtures to the Medeek Electrical Estimator.
        The Electrical Estimator is now complete. I still need to change up the CSI numbers for the various components but for now I've just used my own default numbering system. I will need to get with some electrical contractors on what are the appropriate numbers to use.
        I will now turn my attention to more pressing matters involving the Truss plugin.
        design.medeek.com
        • medeekM Offline
          medeek
          Version 1.2.7 - 02.13.2021
          • Enabled the ability to draw outlets and switches with Medeek Polyline Stemwall assemblies.
          http://design.medeek.com/resources/foundationplugin/images/foundation_su74_800.jpg
          design.medeek.com
          • medeekM Offline
            medeek
            Version 1.2.7b - 02.13.2021
            • Enabled the ability to draw UK outlets and switches with Medeek Polyline Stemwall assemblies.
            http://design.medeek.com/resources/foundationplugin/images/foundation_su75_800.jpg
            design.medeek.com
            • medeekM Offline
              medeek
              Version 1.2.8 - 04.30.2021
              • Added optional metadata parameters for UK outlets and switches: description, circuit.
              • Added a circuit callout parameter in the General tab of the global settings.
              • Added a 5th dimensioning layer specifically for circuit callouts in the Layers tab of the Global Settings.
              • Enabled circuit callouts for the following fixtures: Switches, Outlets, UK Switches and UK Outlets.
              http://design.medeek.com/resources/electricalplugin/images/elec_su225_800.jpg
              http://design.medeek.com/resources/electricalplugin/images/elec_su226_800.jpg
              design.medeek.com
              • medeekM Offline
                medeek
                Version 1.2.9 - 05.30.2021
                • Added an option for vertically offsetting text and symbols within the General tab of the Global Settings.
                • Annotation text and symbols for outlets, switches, UK outlets and UK switches can be vertically offset a custom amount from the bottom of the wall.
                http://design.medeek.com/resources/electricalplugin/images/elec_su227_800.jpg
                http://design.medeek.com/resources/electricalplugin/images/elec_su228_800.jpg
                The default placement was at the bottom of the framed wall, and the default offsets still are zero unless otherwise specified differently. However in most situations this resulted in Z-fighting with the subfloor and if a finished floor was modeled then the symbols and text would be buried within the finished floor or carpet (not visible). This option allows the user to customize the vertical placement to suit their particular needs.
                This update was per customer request.
                design.medeek.com
                • medeekM Offline
                  medeek
                  Version 1.3.0 - 06.01.2021
                  • Added four additional parameters to the "User Interface" section of the General tab of the global settings. This allows the customization (colors) of the HTML menus and buttons.
                  http://design.medeek.com/resources/electricalplugin/images/elec_su229_800.jpg
                  design.medeek.com
                  • medeekM Offline
                    medeek
                    Version 1.3.1 - 06.16.2021
                    • Updated the wiring module/algorithm to improve performance and overall robustness.
                    design.medeek.com
                    • medeekM Offline
                      medeek
                      Version 1.3.2 - 07.11.2021
                      • Enabled subscription and permanent licensing.
                      • The License tab of the Global Settings now displays the license type.
                      design.medeek.com
                      • medeekM Offline
                        medeek
                        Version 1.3.3 - 01.11.2023
                        • Enabled layer control integration with the Medeek Project extension.
                        design.medeek.com
                        • medeekM Offline
                          medeek
                          Version 1.3.4 - 06.13.2023
                          • Enabled switches, outlets and lights to be inserted into "component" walls.
                          Previously electrical fixtures could only be inserted into walls that were "groups", with this update the wall assemblies can be either groups or components.
                          This update per customer request.
                          P.S.
                          I will still need to update the other misc. electrical fixtures (ie. panels, low voltage, safety, heaters, vents, low voltage panels etc...)
                          design.medeek.com
                          • medeekM Offline
                            medeek
                            Version 1.3.5 - 09.29.2023
                            • Added six additional dimmer switch combinations.
                            http://design.medeek.com/resources/electricalplugin/images2/elec_su233_800.jpg
                            design.medeek.com
                            • medeekM Offline
                              medeek
                              Version 1.3.6 - 10.04.2023
                              • Added an offset parameter (advanced options) for outlets which allows the symbol and label to be offset from the wall.
                              • Added two additional advanced parameters for vertically offsetting text and symbols for switches and outlets.
                              http://design.medeek.com/resources/electricalplugin/images2/elec_su235_800.jpg
                              http://design.medeek.com/resources/electricalplugin/images2/elec_su234_800.jpg
                              The text and symbol vertical offsets are driven by the global settings however these two parameters can now be adjusted separately for each individual outlet or switch.
                              This update is per customer request.
                              design.medeek.com
                              • medeekM Offline
                                medeek
                                Version 1.3.7 - 10.14.2023
                                • Added four timer switch combinations (Leviton VPT24-1PZ).
                                http://design.medeek.com/resources/electricalplugin/images2/elec_su236_800.jpg
                                Added per customer request.
                                design.medeek.com
                                • medeekM Offline
                                  medeek
                                  Version 1.3.8 - 11.22.2023
                                  • Added two additional parameters for annotation formatting.
                                  • Added the "Regen Electrical" function to the primary toolbar, enabled regeneration for all electrical fixtures.
                                  • Moved the "Draw Safety Device" tool to the secondary toolbar.
                                  http://design.medeek.com/resources/electricalplugin/images2/elec_su237_800.jpg
                                  http://design.medeek.com/resources/images/electrical_su_menu_active.jpg
                                  http://design.medeek.com/resources/images/electrical_ii_su_menu_active.jpg
                                  design.medeek.com
                                  • medeekM Offline
                                    medeek
                                    Version 1.3.8b - 11.23.2023
                                    • Added the "Symbol Text Scale" parameter for scaling superscript of 2D electrical symbols.
                                    http://design.medeek.com/resources/electricalplugin/images2/elec_su238_800.jpg
                                    http://design.medeek.com/resources/electricalplugin/images2/elec_su239_800.jpg
                                    With this update one can scale the 2D symbol superscript of the electrical symbols and make them more visible and legible when exporting to Layout, PDFs or paper.
                                    design.medeek.com
                                    • medeekM Offline
                                      medeek
                                      Tutorial 6 - Annotation Formatting (9:47 min.)
                                      design.medeek.com
                                      • medeekM Offline
                                        medeek
                                        Version 1.3.9 - 01.08.2024
                                        • Updated and improved the license verification module.
                                        • Disabled redundant logging to improve plugin performance.
                                        design.medeek.com
                                        • medeekM Offline
                                          medeek
                                          Version 1.4.0 - 01.12.2024
                                          • Added a "PIPE" shape to the wire module for electrical conduit.
                                          • Added an additional parameter for custom wires (conduits/pipes) within the library: Wall Thickness.
                                          • Added standard PVC (Schedule 40) electrical conduit sizes into the custom wire library.
                                          Note, that previous custom wire libraries will not be compatible with this latest update. If you have an extensive library already established please contact me directly with step-by-step instructions on how to bring an older wire library into this latest version of the plugin.
                                          http://design.medeek.com/resources/electricalplugin/images2/elec_su241_800.jpg
                                          http://design.medeek.com/resources/electricalplugin/images2/elec_su240_800.jpg
                                          The dimensions for the OD, wall thickness and bend radius were taken directly from CANTEX and JM Eagle literature, and should match exactly the standard specs for SCH40 PVC in the American and Canadian markets.
                                          design.medeek.com
                                          • medeekM Offline
                                            medeek
                                            Version 1.4.1 - 01.31.2024
                                            • Improved the serial number verification logic within the License tab of the Global Settings.
                                            • Updated the javascript logic within the License tab of the Global Settings.
                                            • Added standard PVC (Schedule 80) electrical conduit sizes into the custom wire library.
                                            • Fixed a minor bug with the edit wire profile logic of the wire module.
                                            http://design.medeek.com/resources/electricalplugin/images2/elec_su242_800.jpg
                                            It turns out the outer diameter and bend radius of schedule 80 conduit is the same as schedule 40, only the wall thickness is different. I learn something new everyday.
                                            design.medeek.com
                                            • 11
                                            • 9 / 11
