    πŸ”Œ Easy Offset | Offset selected faces in SketchUp in positive and negative offsets. Download
    Medeek Electrical
    204 Posts 6 Posters 220.8k Views 5 Watching
    • medeekM Offline
      medeek
      Tutorial #1 - Extension Overview:
      Footnote: The bug encountered at the 16:00 min. mark has been identified and corrected.
      Nathaniel P. Wilkerson PE
      Medeek Engineering Inc
      design.medeek.com
      • medeekM Offline
        medeek
        There is always more that can be done. Just remember though I am juggling four different extensions now, single handed and each one is very deep (and broad). So my time to devote to any one plugin or request is becoming much more selective.
        If you would like to have a feature added I need more details:
        1.) Most common configuration and manufacturer.
        2.) Some indication of how much this feature would be used (does it fit the 90% rule).
        3.) Commercial or Residential application.
        design.medeek.com
        • medeekM Offline
          medeek
          Version 0.9.1b - 02.19.2019
          • Enabled the ability to draw outlets with any wall geometry (removed the dependency on the Medeek Wall extension).
          design.medeek.com
          • medeekM Offline
            medeek
            Version 0.9.1c - 02.19.2019
            • Enabled the ability to draw low voltage outlets, load centers and light fixtures with any wall geometry (removed the dependency on the Medeek Wall extension).
            The plugin is now fully independent of the Medeek Wall extension and can function as a standalone extension.
            design.medeek.com
            • medeekM Offline
              medeek
              Its funny how some of my best thinking is done when I am doing totally unrelated tasks. While I was cleaning out my garage and mini-van on Sunday afternoon I slowly started working out how to handle ceiling mounted light fixtures, almost unconsciously before I was aware that I was working on the problem.
              After giving this topic a rest for a few days and then revisiting it again this evening it is now clear to me that in order for this to work properly I really need a "Story" or "Levels" module or plugin that actually works across all of the plugins. This Levels module is also needed for the other plugins in the mdkBIM suite, especially in relation to estimating.
              This becomes critical for the electrical plugin because when you start placing fixtures into a ceiling you need to know where the floor is in relation to that ceiling. Or to be more precise you need to know which floor to assign the light fixtures to so that the 2D symbols are drawn at the appropriate Z height and hopefully are at the same level as the rest of the electrical symbols for that level (ie. wall mounted electrical fixtures), regardless of the ceiling height.
              If the absolute Z height of the Level is changed then the 2D symbols assigned to it will need to move up or down to make the adjustment. The easiest way to do this is to place all of the 2D symbols (ceiling light fixtures only) in an over arching group that is separated from the separate light fixture groups themselves. When the Level Z height changes you only need to move this main group and not each 2D symbol.
              The potential downside with this particular system is that if you manually move one of the light fixtures in the X-Y plane or laterally then the 2D symbol does not follow it and is out of sync (out of position). The way around this problem is to possibly setup an observer so that if a ceiling fixture is moved the 2D symbol is simply deleted and redrawn. When a ceiling fixture is deleted a similar situation occurs, however the symbol will always belong to the appropriate main group and have a tag (instance name) that matches the ceiling fixtures so that it can be easily purged from the main group.
              The draw tool will not only be looking at the group (ceiling group) but also at the face when placing the fixture. The exact point selected on the face will determine the actual placement of the fixture. The height parameter (fixture to floor distance) as it is currently defined has no meaning and will be greyed out however for certain suspended fixtures it can be used at the "suspended height" thereby determining the height above the fixture to place the junction box within the suspended ceiling.
              There is quite a bit to consider when it comes to ceiling mounted fixtures, I'm sure I haven't considered every possibility yet and there may even be a fatal flaw in some of the organization explained above but at least I wanted to get some of my thoughts down in writing before they evaporated away like a morning mist under the noon-day sun.
              design.medeek.com
              • medeekM Offline
                medeek
                I will no longer be posting updates to this thread.
                If you are interested in new developments or the continuation of this thread please visit:
                403 - Forbidden: Access is denied.
                (design.medeek.com)
                design.medeek.com
                • jujuJ Offline
                  juju
                  dang
                  registered, how long does approval take?
                    MtnArch
                    It took a couple of hours for me .. hopefully Nathan's gotten yours out to you too by now.
                    Highest Regards,
                    Alan T. Hendry, RA
                    Architect
                    • medeekM Offline
                      medeek
                      Version 0.9.6 - 03.09.2019
                      • Fixed bugs related to compatibility with SketchUp 2015.
                      design.medeek.com
                      • medeekM Offline
                        medeek
                        Update available - 03.19.2019
                        Medeek Design Inc. - Medeek Electrical Plugin Changelog
                        (design.medeek.com)
                        design.medeek.com
                        • medeekM Offline
                          medeek
                          Update available - 03.21.2019
                          (design.medeek.com)
                          design.medeek.com
                          • medeekM Offline
                            medeek
                            Version 1.0.0 - 03.23.2019
                            - The Medeek Electrical extension moved from BETA status to initial full release.
                            • Created the HTML edit panel menu and enabled editing for load centers (service panels).
                            • Created the HTML edit safety device menu and enabled editing for wall and ceiling mounted safety devices (exit signs, smoke detectors, CO detectors, horn/strobes).
                            • Created the HTML edit light fixture menu and enabled editing for wall and ceiling mounted light fixtures.
                            design.medeek.com
                            • medeekM Offline
                              medeek
                              Tutorial 2 - Light Fixtures (17:50 min.):
                              design.medeek.com
                              • medeekM Offline
                                medeek
                                Justin Geis with SketchUp Essentials just posted a review of the plugin:
                                Overall I think the video is excellent however the demo was of version 0.9.6 so he was not able to demonstrate the parametric ability of the plugin.
                                design.medeek.com
                                • medeekM Offline
                                  medeek
                                  Version 1.0.1 - 03.28.2019
                                  • Parameter hightlight (input) color added to General tab of global settings.
                                  • Fixed a bug with the safety devices module.
                                  http://design.medeek.com/resources/images/electrical_su38_800.jpg
                                  design.medeek.com
                                  • medeekM Offline
                                    medeek
                                    The light fixture module actually needs to be more like the safety device module where you have a custom library for certain classes of lights and the corresponding symbol.
                                    I need to add in the following light types and symbol:
                                    • Vanity
                                    • Fluorescent (surface, suspended, recessed)
                                    • Ceiling Fan
                                    • Ceiling Fan w/ Light
                                    • Canister (Can Light)
                                    • Surface
                                    • Suspended
                                    I'm also debating whether to add in something for enclosed vents/fans for (bathrooms, laundry rooms, kitchens). Technically this is part of the HVAC or mechanical system but usually gets tucked into the electrical plan, thoughts?
                                    design.medeek.com
                                    • medeekM Offline
                                      medeek
                                      I will be adding in an additional toolbar "Medeek Electrical II":
                                      http://design.medeek.com/resources/images/electrical_ii_su_menu_active.jpg
                                      This toolbar will be for misc. electrical devices that do not fit neatly into the categories already provided (switches, outlets, low voltage, load centers, safety, light fixtures).
                                      The first two items that will be added are: Heaters, Vent (fans)
                                      3D Warehouse
                                      3D Warehouse is a website of searchable, pre-made 3D models that works seamlessly with SketchUp.
                                      (3dwarehouse.sketchup.com)
                                      Heaters will include items such as cadet wall heaters, shop/garage ceiling mount heaters etc...
                                      Vents will include typical ceiling mount vent fans for bathrooms, laundry and kitchens. Regular ceiling fans and ceiling fans with lights will actually be included with the light fixtures module.
                                      design.medeek.com
                                      • medeekM Offline
                                        medeek
                                        Version 1.0.2 - 04.01.2019
                                        • Created the Medeek Electrical secondary toolbar, with two additional functions/tools: Draw Heater, Draw Vent.
                                        • Enabled the ability to draw ceiling (garage/shop) and wall mount heaters.
                                        • Enabled the ability to draw ceiling mount exhaust fans, with or without light.
                                        http://design.medeek.com/resources/images/electrical_su39_800.jpg
                                        If you would like to see a specific piece of electrical hardware or device added to the plugin please let me know, I am very open to suggestions on how to make this plugin more useful.
                                        I've had numerous requests for extending the plugin to encompass the British electrical standards however no one has sent me any literature (or links to literature, manufacturers etc...) or low poly models. I am interested in making this plugin more universal and extending its coverage to other electrical standards however I don't have enough experience with these others standards yet and I will need more guidance if I am to do this correctly.
                                        design.medeek.com
                                        • medeekM Offline
                                          medeek
                                          design.medeek.com
                                          • medeekM Offline
                                            medeek
                                            I need to add in the option for ceiling fans and ceiling fans with lights.
                                            What would be the suggested 2D symbol for these two light fixture options, I would like to keep it fairly simple but appealing.
                                            design.medeek.com
                                            • 6
                                            • 10
                                            • 11
                                            • 4 / 11
