    Help K2WS_Tools
    3 Posts 3 Posters 1.1k Views 3 Watching
    • nanolinN Offline
      nanolin
      I need some help to make an adaption for this , i would like join a componnet by minifix
      http://albuerne.com/img/262_28_928_.jpg
      • K Offline
        ktkoh
        I have not looked at the forum for while so I just saw your question. Are you wanting to make the detail in both parts at the same time? That would be a difficult program.
        You could use the dowel tool to make the thru hole for the bolt in both parts by making the hole in part2 a thru hole and using dowel data to get the proper dept in part 1. The cross hole would be a problem for my program an programing skills as it requires a intersection. You would need to draw a cylinder and use solid substract tool to create that detail. Booltools2 is a free plugin that would do that.
        • K Offline
          kostiaarh
          Take a look https://www.youtube.com/watch?v=9GbwPRm7qxg&t=153s
