    Phasing in SU - similar to revit
    extensions
    6 Posts 4 Posters 3.2k Views 4 Watching
    • M
      monkers
      Hi Guys,
      I'm wondering if there is a good way/workflow to do phasing in SU - Similar to how Revit does it;
      I guess its kinda like DC each object would have a "properties" panel and you could select phase created and phase deleted. This could link up to a scene which would be allocated a phase and give options to show/hide various phases plus or minus the deleted work to aid with scheduling works. I no expert but I feel like utilizing DC this wouldn't be difficult to do.
      Any thoughts or directions I should investigate to make this happen?
      Cheers.
      On another note - We are currently looking for contractors to do some custom plugins/extensions for our business if you are interested hit me up.
      • R
        rv1974
        Combination of layers on/off saves in scenes
        • M
          monkers
          We do this with a couple of other plugins but it's pretty time-consuming. 20 odd scenes/phases and when you add a new layer it's on every scene so each object would have to have its own layer. Some jobs I end up with 200 odd layers...
          • jujuJ
            juju
            What he said.
            That can be changed / managed by extensions, AFAIK.
            • R
              rv1974
              check Jim's 'Add hidden layer'.
              Additionally, there was something like 'scene\layer matrix' -I don't remember exact name. The plugin in form of table to control layers visibility through all your scenes.
              But I never used it, 'Add hidden layer' is good enough for me.
              • D
                db11
                It's called VisMap2 by Martin Rinehart. It was updated for 2015 by Jim Foltz, but haven't tried it yet in 2018. It's a very useful extension, and I would love to see someone create a new version of it.
                I also use Jim's Add Hidden Layer plugin regularly and recommend it.
