    [req] place components over a line
    4 Posts 2 Posters 842 Views 2 Watching
    • P Offline
      pibuz
      Hi to the community!
      I have another curiosity: I don't know if it is possible with the current tools to arrange a row of pre-selected components over a line (sort of the way profile builder does), and set a component to be placed wherever the line we are drawing makes a 90Β° (or selectable) angle....
      If you like, it's sort of a "fence" plugin, where you can actually choose the components between the pickets, and the path along which you have to run has some corners....
      Do you gyus have some hints for me?
      THANK YOU A LOT!
      WEB (ita) - https://filipposcarso.wixsite.com/ordinentropico
        Without image of what you want that is some difficult to answer πŸ˜„
        Something like this ?
        https://sketchucation.com/forums/download/file.php?id=153561
        • P Offline
          pibuz
          HI Pilou!! Thanks for your immediate answer!
          ...basically yes!
          The firm I'm working for is looking a way to speed up the process of modeling: the work is about fair trading, so they basically have a base component for walls (say 100x300cm, th.4cm) which they spread around for whole pavilions. The base panel has tons of options but I'm trying to set dynamic components. Now I am looking for a plugin which could place the base components one close to each other (therefore every 100cm), and automatically place a "pillar" component (4x4x300cm) where I have the corners.
          A great thing would also be the option to enter the length of the line (say "800") and to obtain an array of 8 elements with automatic placing of the pillar at the start+end of the measure, then specify another direction, enter a second value (say 400) and have a pillar placed at the end, and so on....
          Sorry for not posting images, I don't know how to explain this!!!!!
          PS. I am sure to have seen a "click-rotate" plugin somewhere (a plugin which can rotate a component along his blue axis with a click) here but seems like I can't find it anymore. Any of you guys recall it too? THANK YOU SO MUCH!
            Rotate around axe pivot By Thomthom?
            https://sketchucation.com/pluginstore?pln=tt_axis_pivot
            This one can be useful too
            Axes Tools By Thomthom
            https://sketchucation.com/pluginstore?pln=tt_axes
