    Select Style for drawing
    8 Posts 2 Posters 7.4k Views 2 Watching
    • U Offline
      UncleString
      Construction Documentation Style.jpgIs there a way to select a style for my drawing?
      I would like it to use "Construction Documentation Style"
      Here is the code I am using to save the image.
      ` model = Sketchup.active_model
      entities = model.active_entities
      Sketchup.send_action("viewIso:")
      view = model.active_view
      Puts in SketchUp install directory by default
      status = view.write_image "test.jpeg"
      keys = {
      :filename => "S:/Stairs/Stair Pics/write_image.jpeg",
      :width => 500,
      :height => 400,
      :antialias => false,
      :compression => 0.5,
      :transparent => false
      new_view = view.zoom_extents
      view.write_image keys`
        Your code seems to be saving an image of the model.
        And I expect that's not what you want ?
        The API includes several distinct methods for affecting a model's 'Styles'...
        http://ruby.sketchup.com/Sketchup/Styles.html
        http://ruby.sketchup.com/Sketchup/Style.html
        http://ruby.sketchup.com/Sketchup/Page.html#style-instance_method
        http://ruby.sketchup.com/Sketchup/Page.html#use_style%3F-instance_method
        etc
        To 'load' a particular Style you need to get the path to its .style file...
        There are ways to find this in Ruby...
        But on a PC I think it's easy to get through:
        desired_style_file_path = 'C:\ProgramData\SketchUp\SketchUp 2018\SketchUp\Styles\Default Styles\08Construction Documentation Style.style'
        Then use that to set the Style ??
        • U Offline
          UncleString
          Thanks,
          I could not find the actual file location, I was able to right click on the style and save it to a different location, and use that address to for the code.
          While this code does change the style.
          #---------------Change Style----------
          filename = File.expand_path('C:\Users\dmorrison\Downloads\08Construction Documentation Style.style')
          styles = Sketchup.active_model.styles
          status = styles.add_style(filename, true)
          keys = {
          :width => 500,
          :height => 400,
          It does not change in my actual plugin.
          The last lines of the plugin to insert the image into excel
          ` #-----Pictures Insert Code---------------
          #require 'win32ole'
          filename = File.expand_path('C:\ProgramData\SketchUp\SketchUp 2015\SketchUp\Styles\Default Styles\08Construction Documentation Style.style')
          keys = {
          :width => 500,
          :height => 400,
          worksheet.pictures.delete
          pic = worksheet.Pictures.Insert('S:\Stairs\Stair Pics\write_image.jpeg')
          range = worksheet.Range('a14:e32')
          pic.ShapeRange.LockAspectRatio = false
          pic.Top = range.Top
          pic.Left = range.Left
          pic.Width = range.Width
          pic.Height = range.Height`
            So you have the Style changing as you hope.
            Does your middle code write the images you expect.
            You seemingly pointless " test.jpeg" will go in the current working directory.
            To find that use p Dir.pwd in the Ruby Console...
            It might NOT be the main SketchUp folder...
            Running the code with the Console open might help spot errors etc...
            will only work if the folder "S:/Stairs/Stair Pics" exists - does it ?
            So is this image getting saved ?
            I suddenly realized that you briefly mention v2015 in your code.
            So the default Styles are [probably] in another location - I only have >=v2017 on this PC so I can't confirm...
            I think that the write_image method using a key only works for PNG files in older SketchUp versions - try that PNG file-type and see if it helps...
            Saving images as a JPG with a key etc are only supported in newer SketchUp versions - in older SketchUp versions you need to pass overloads as arguments listed after the file path...
            See here...
            http://ruby.sketchup.com/Sketchup/View.html#write_image-instance_method
            Also the [#]require 'win32ole' might not work with older SketchUp versions !
            It's only been shipped since the Ruby set up changed...
            In that case you might need to include an equivalent .so in your own subfolder and load that manually ??
            • U Offline
              UncleString
              Thanks Tig,
              The image does end up in excel, but not with the correct style
              Pic in excel
                What version of SketchUp are you using ?
                Let's break this down into individual steps.
                1. Add and activate Style
                  pause
                2. Export Image
                  pause
                3. Add Image to Excel
                For 1. - does it add and activate the Style as you hope ?
                For 2. - does it export an Image using the expected Style [and view, zoom etc] ? Is the actual JPG file what you want ?
                For 3. - is there a preexisting Image in the Excel file ? Is the Image imported the one seen in 2. ?
                At the moment your "reporting" is clear to you but unclear to the rest of us !
                • U Offline
                  UncleString
                  Okay, there is something very strange. I spent a lot of time trying to figure out why it would not pause or even show a msgbox as it was going through the code. I commented out the entire code and got nothing, I un-commented just the 1st line and the code produced a drawing, I don't know what code it used as I had all the code commented out.
                  For example
                  ` UI.menu("PlugIns").add_item("Get From Excel") { get_from_excel }
                   # def get_from_excel
                  ents=Sketchup.active_model.active_entities
                  require 'win32ole'
                  xl = WIN32OLE::connect('Excel.Application')
                  workbook = excel.Workbooks('Stair_Info_to_Sketchup')
                  worksheet = workbook.Worksheets(1)
                  How is this possible? I am going to assume it was is obviously running a code from somewhere else, but I can't locate it.
                  • U Offline
                    UncleString
                    I found it, it was a test .rb file, not a plugin but it did have
                    def get_from_excel
                    That is where the plugin was getting the code from.
                    Thank you,
                    The style does change now that I am in the correct code.
