    Grade contours around wall
    3 Posts 2 Posters 2.7k Views 2 Watching
    • B
      Bob_CP
      Hello all
      In this model, I'm trying to generate a grade around the retaining wall. If I select the contour lines, neither the native sandbox tools and Fredo's Toposhaper deal properly with the grade separation on either side of the retaining wall. I'm trying to figure out the quick and easy way to do this. I've been experimenting with selecting just some of the contour lines at a time, generating the grade with the intent to combine the shapes, but that seems like a laborious process and I'm not sure the issues that lie down that path, because of the overlaps created this way.
      So, I thought someone here may have dealt with this and has a better solution.
      Thanks in advance!
      Bob
      Contour problem.skp
      • srxS
        srx
        They are not so smart ๐Ÿ˜„
        You have to separate surface in several groups which does not break, and than use the tools.
        Contour problem.skp
        www.saurus.rs
        • B
          Bob_CP
          Yea, I'm trying that in several different ways right now.
          Thanks for responding!
          Bob
