    Terrain modification/triangle control
    3 Posts 3 Posters 1.5k Views 3 Watching
    • I
      IntelCoreDuo
      I'm trying to make a basin for a water feature. I've defined an area which I want lowered a bit. However, when I lower it, the triangulation becomes really weird as shown below. This can be fixed by adding a bunch of lines manually as shown. Any way to achieve this automatically?
      what i want lowered
      what happens
      How to fix it manually
      The result I want, preferably without all that manual input
        Look at Split tools by TIG
        • srxS
          srx
          If you close the curve around the lake so it is almost offset of it, and than move the lake, I guess it will be ok. You could start with offseting the lake to have a guide.
          www.saurus.rs
