    Layout, hatch/ pattern fill
    layout
    4 Posts 4 Posters 6.7k Views 4 Watching
      millerjx
      Is there a way to have a void inside of a hatch pattern?
      For example to hatch a floor, but not the 24"x24" columns in the middle
      • pbacotP Offline
        you know it's hard to say, depending on how you are making your drawing. Just in terms of simple drawing, one can place a filled rectangle in the column area etc.
          shawb
          A workaround for this would be to hide the floor element in the SU view and then place the hatch on a layer below the Sketchup model layer in Layout. Hope this is what you meant - I tried it with both a sectioned and a non-sectioned view. Layout file in version 2015 attached.
          Hatch layer 13 08 2018.layout
          • RichardR Offline
            Richard
            An easy workaround:
            1. Create a bold rectangular 'C' shaped object with the line tool.
            2. Fill this object with hatch and double-click the object to enable path editing to close the 'C'.
            3. Disable the object's stroke.
            4. Redraw all outlines to the object with a 'stroke' enabled and 'fill' disabled.
            [BUILTBRAND.COM.AU](http://builtbrand.com.au/)
