    Shrink Plugin Window
    extensions
    3 Posts 2 Posters 3.4k Views 2 Watching
      Coyote86
      I have installed the Round Corner plugin and when I open it I get this shrink window (see snapshot).
      Has anyone faced this problem before and sorted?
      Any help will be appreciate it.
      Regards
      Leandro
      NOTE. The version of Sketchup I´m running at the moment is Sketchup 2016 Pro and I´m using a Microsoft Surface Book 2 13´´ laptop.
        dezmo
        Yes I'm constantly get similar problems with Surface Pro 4. Not only in Sketchup . There is no real solution just compromise. Until the programmers will not apply proper programming for the high resolution displays. (I'm talking about windows programmers, application programmers and plugin programmers...)
        I assume, the problem is the high DPI screen.
        1, You can try to override the default high DPI setting for Sketchup like this:
        Compatibility tab
        2, Try to change: in the windows display setting : Scale and/or resolution
        Man can do everything. Only a matter of time and money.
          Coyote86
          Hi Dezmo,
          Thanks for your reply.
          I have tried you suggestion but this creates other Sketchup windows to shrink or oversize too.
          Thus, I left the compatibility as it was before.
          Regards
          Leandro
