    Controlling line width
    2 Posts 2 Posters 984 Views 2 Watching
    • I Offline
      Involute
      In order to cut something on my laser cutter, I need to make the cut lines .001" wide. If I create the artwork in SketchUp, I export in .dxf, import it into Illustrator, change the line width in there, and export as pdf, which is what I print with. Is there a way to keep the workflow in SU? I assume no, as I don't think there's a way to specify line width in SU, but figured I'd check here. I'm on SU Pro 2018 on Win10. Thanks.
      • jujuJ Offline
        juju
        Please update your profile info.
        About your query, unless you thicken the lines out manually (or with the help of some extension), I don't think you can do what you require straight from SU.
