Change the style in multiple scenes
I am curious. I have a style, the same in every scene but now I want to replace it with another style, without having to adjust everything in the original style. I can bring a style from a collection into the model, but how do I replace the original style in all the scenes without having to update it for each scene individually. SketchUp will not replace/ overwrite the original style if I give them the same name.
Its late but try this:
Bring in your new style to the model so that it appears in the 'In Model' panel of the Styles window.
In the Scenes panel Shift_select all the scenes shown for the model.
Un-check all the options except 'Camera Location'
Click on the desired new style in the 'In Model' panel
Re-check all the other options that you require including 'Style & Fog'This should have changed all scenes to the new style. Hope this is okay!
I think I was trying something like this but did it wrong. It seems to work OK. Only thing is I would only uncheck style and fog, because I noticed that section cut settings are lost (and probably some other things if I uncheck everything but camera. Unfortunately if you are using different fog settings, they are probably all set to one setting in this process, since style and fog are combined. Thanks.
Register LoginAdvertisement
