    [Plugin (final version)] Section Planes Manager
    27 Posts 13 Posters 10.9k Views 13 Watching
    • Didier BurD Offline
      Didier Bur
      Hi all,
      Here is a little plugin I needed for my personal use. When having a bunch of section planes in the model, it can be quite annoying to have to activate a particular section plane (display section planes, select the desired one, right-click and choose "activate", etc).
      This plugin lets you select the section plane in a dialog box, and more.
      Usage: select "Sections Manager" from the Window menu.
      (2 languages included: fr,us)
      For SU v2018 and up.
      Final version 06/06/18 (RBZ extension):
      2 languages included: french, english. Easy to localize for your own language.
      See PDF help file included (click on the ? button).
      DBUR_SectionsManager_v110.rbz
      DB
      • JQLJ Offline
        JQL
        It's a very cool idea! Thanks for sharing. Does it use sections in hidden layers?
        www.casca.pt
        Visit us on facebook!
        • srxS Offline
          srx
          Very useful. No more trying to pick the right one...Thank you.
          www.saurus.rs
          • pbacotP Offline
            Excellent idea. I was surprised there was no way to do this in SU. (Why aren't section planes in "Outliner"?).
            Thanks for sharing!
            • BepB Offline
              Bep
              merci pour votre générosité
              "History is written by the winners"
              • JQLJ Offline
                JQL
                Thanks for sharing!
                have you uses2018?
                www.casca.pt
                • P Offline
                  pedrinalex
                  Many, many thanks to you,
                  MB ASUS x99M-WS, Xeon e5 2695 v3, 64 GB RAM 2400, 2x gforce gtx 1060, 1 SSDH 1 tb & 3 HD 1 TB c/u
                    Didier Bur
                    @ pbacot,
                    Sections are in the Outliner (new in version 2018 I think)
                    About hidden layers: if your sections are on a hidden layer, the plugin also works, but you will not see the sections planes appear in the viewport. Same goes for sections that are hidden entities (masked).
                    Maybe I'll enhance the script to make them appear and hide them again after the command ends 😉
                    DB
                    • srxS Offline
                      srx
                      Does it work in 2017?
                      www.saurus.rs
                      • JQLJ Offline
                        JQL
                        Hi Didier,
                        For me it's perfect then, I wouldn't need to see section planes at all, because the section would be active and that's enough for me.
                        However, if you're willing to improve the plugin, how would you feel about having it in a floating window instead of a dropdown menu?
                        I would definetelly use that a lot, having a section's list floating on the side, double clicking a section and it would then become active, even if invisible. In fact it would look like outliner without the model part of it. Having the outliner open all times doesn't work at all because it will slow down Sketchup or actually bog it down a lot of times when using plugins. Having an outliner dedicated exclusivelly to sections would be oh so great!
                        www.casca.pt
                          Didier Bur
                          @srx:
                          No, it won't work in SU2017, because sections names and symbols were introduced in SU2018.
                          DB
                          • BoxB Offline
                            It would be worth attaching it as an .rbz since that is the more commonly recognized file extension these days for plugins. Many newer users may not know what to do with an .rb or know where to find their plugin folder.
                              Didier Bur
                              @Box and JQL:
                              Done. See top of this topic.
                              Enjoy !
                              DB
                              • PixeroP Offline
                                Pixero
                                Thanks. Will come in handy.
                                • JQLJ Offline
                                  JQL
                                  @didier bur said:
                                  @Box and JQL:
                                  Enjoy !
                                  oh yeah!
                                  www.casca.pt
                                  • jujuJ Offline
                                    juju
                                    @jql said:
                                    Hi Didier, I've tried it and it's really good.
                                    JQL, do you use Skalp? If so, have you tried the two together? Any conflicts?
                                    • JQLJ Offline
                                      JQL
                                      I don't use Skalp.
                                      www.casca.pt
                                      • JQLJ Offline
                                        JQL
                                        I made a mockup as what I was actually thinking was something like this:
                                        This way we could see the list of all sections and easily navigate in the model (as long as section names are easy enough which, since 2018, can be controlled)
                                        I then went ahead and added a few feature requests to the UI too:
                                        1 - Double Click would replace the Apply Button;
                                        2 - A single click would select a given section (select in the list and in viewport);
                                        3 - CTRL/SHIFT would add/remove sections to the selection;
                                        4 - Delete selected section(s) from list;
                                        5 - And why not add a section while working with the list;
                                        6 - Then duplicate seemed natural too as you could duplicate selected sections then select in the list and move around in the viewport.
                                        I know this is asking too much, but who knows?...
                                        Thanks!
                                        EDIT: The plus, minus, duplicate and delete icons are a copy paste from skatter dialog which I believe is inspired in Sketchup's.
                                        www.casca.pt
                                          Didier Bur
                                          Hi all,
                                          Here is what I ended up with 😉
                                          Dropdown list now updates automatically when you add, erase, or modify a section.
                                          The section plane that you select in the list is activated immediately (no need to click on a "apply" button anymore).
                                          Tooltips added when mouse hovers icons
                                          The row of icons, left to right, do the following:
                                          • invert the section plane (toggle)
                                          • add a section plane
                                          • show all section planes (toggle)
                                          • draw the section or not (toggle)
                                          • fill or not the section (toggle)
                                          • align view to the section plane
                                          • perspective/parallel camera (toggle)
                                          • display help file
                                          See top of this topic to download the latest RBZ version.
                                          Enjoy!
                                          DB
                                            Didier Bur
                                            Enjoy!
                                            DB
                                            • 1 / 2
