    [Plugin (final version)] Section Planes Manager
    27 Posts 13 Posters 11.6k Views 13 Watching
    • Didier BurD Offline
      Didier Bur
      @srx:
      No, it won't work in SU2017, because sections names and symbols were introduced in SU2018.
      DB
      • BoxB Offline
        It would be worth attaching it as an .rbz since that is the more commonly recognized file extension these days for plugins. Many newer users may not know what to do with an .rb or know where to find their plugin folder.
          Didier Bur
          @Box and JQL:
          Done. See top of this topic.
          Enjoy !
          DB
          • PixeroP Offline
            Pixero
            Thanks. Will come in handy.
            • JQLJ Offline
              JQL
              @didier bur said:
              @Box and JQL:
              Enjoy !
              oh yeah!
              www.casca.pt
              Visit us on facebook!
              • jujuJ Offline
                juju
                @jql said:
                Hi Didier, I've tried it and it's really good.
                JQL, do you use Skalp? If so, have you tried the two together? Any conflicts?
                • JQLJ Offline
                  JQL
                  I don't use Skalp.
                  www.casca.pt
                  • JQLJ Offline
                    JQL
                    I made a mockup as what I was actually thinking was something like this:
                    This way we could see the list of all sections and easily navigate in the model (as long as section names are easy enough which, since 2018, can be controlled)
                    I then went ahead and added a few feature requests to the UI too:
                    1 - Double Click would replace the Apply Button;
                    2 - A single click would select a given section (select in the list and in viewport);
                    3 - CTRL/SHIFT would add/remove sections to the selection;
                    4 - Delete selected section(s) from list;
                    5 - And why not add a section while working with the list;
                    6 - Then duplicate seemed natural too as you could duplicate selected sections then select in the list and move around in the viewport.
                    I know this is asking too much, but who knows?...
                    EDIT: The plus, minus, duplicate and delete icons are a copy paste from skatter dialog which I believe is inspired in Sketchup's.
                    www.casca.pt
                      Didier Bur
                      Hi all,
                      Here is what I ended up with 😉
                      Dropdown list now updates automatically when you add, erase, or modify a section.
                      The section plane that you select in the list is activated immediately (no need to click on a "apply" button anymore).
                      Tooltips added when mouse hovers icons
                      The row of icons, left to right, do the following:
                      • invert the section plane (toggle)
                      • add a section plane
                      • show all section planes (toggle)
                      • draw the section or not (toggle)
                      • fill or not the section (toggle)
                      • align view to the section plane
                      • perspective/parallel camera (toggle)
                      • display help file
                      See top of this topic to download the latest RBZ version.
                      Enjoy!
                      DB
                        Didier Bur
                        Enjoy!
                        DB
                        • pbacotP Offline
                          Especially helpful when updating scenes! You don't have to make section planes visible and then hope you can select the one you want (if you don't have all sections per layer like you should, nearly impossible). Then try to update the scene correctly without planes visible etc.
                            Charlie__V
                            Didier,
                            Awesome....simply awesome.....greatly appreciate you sharing this plug-in!
                            Charlie
                            • boofredlayB Offline
                              boofredlay
                              @didier bur said:
                              Usage: select "Activate section plane" from the Tools menu.
                              (six languages included: fr,us,de,nl,es,pt,it)
                              For SU v2018 and up.
                              Your original post says this plugin is in the Tools Menu but on my machine it shows up in the Window Menu.
                              Cheers.
                                Didier Bur
                                @boffredlay:
                                You're right. Fixed 😉
                                Side note: I'll soon publish an enhanced version with another new feature: automatic sectional view creation (scene, layer, material and style options).
                                DB
                                • zooenZ Offline
                                  zooen
                                  Bonjour Didier,
                                  Avec SU 2020, j'ai ce rappel à chaque changement de scène si je n'ai pas créé de section.
                                  Il doit y avoir un moyen de désactiver cette petite boîte (je suis obligé de cliquer deux fois sur OK pour qu'elle disparaisse).
                                  Hello Didier,
                                  With SU 2020, I have this reminder at each scene change if I haven't created a section.
                                  There must be a way to deactivate this little box (I have to click OK twice so that it disappears).
                                    pibuz
                                    @didier bur said:
                                    @boffredlay:
                                    [attachment=0:1xckhsb2]<!-- ia0 -->coupe.jpg<!-- ia0 -->[/attachment:1xckhsb2]
                                    HI DIDIER! WONDERFUL PLUGIN!
                                    I don't know how I could have missed that!!!!
                                    Any chance you finally finished the textured section face mod?
                                    WEB (ita) - https://filipposcarso.wixsite.com/ordinentropico
                                      Didier Bur
                                      Too much work at the moment 😉 Due to lockdown, all my courses with Zoom,Teams,GoToMeeting are taking all my time 😄
                                      Regards,
                                      DB
