    Window Screening
    4 Posts 3 Posters 2.1k Views 3 Watching
    • G Offline
      garystan
      Hi everybody :
              Using a window frame that I created, how do I create "window screening" for it ?  The kind of screening you use on patios.
      Thanks garystan
      • Bob JamesB Offline
        Bob James
        The problem with screening is that its wires are so close together that from a distance it will look solid black.
        • G Offline
          garystan
          Bob James :
          I think you're right. I was trying to make a screen mesh component, for a window frame. And like you said, from a distance it DOES look black. Even when I adjusted the "visibility" (I can't think of the word), it didn't help. Thanks for your words of wisdom.
          garystan
          • pbacotP Offline
            I would just use a translucent gray material.Looks fine.
