Window Screening
Hi everybody :
Using a window frame that I created, how do I create "window screening" for it ? The kind of screening you use on patios.
Thanks garystan
The problem with screening is that its wires are so close together that from a distance it will look solid black.
Bob James :
I think you're right. I was trying to make a screen mesh component, for a window frame. And like you said, from a distance it DOES look black. Even when I adjusted the "visibility" (I can't think of the word), it didn't help. Thanks for your words of wisdom.
garystan -
I would just use a translucent gray material.Looks fine.
