    IPin Pro - Ideal for one-man building surveys!
    9 Posts 8 Posters 353.8k Views 8 Watching
    • Mike LuceyM
      Mike Lucey
      Hi Guys,
      I think the iPin Pro will be attractive to anyone that completes building surveys. I don't complete as many as I used to which involved two persons a lot of the time. This device eliminates the need for a second person as the user simply takes photos and extrapolates the height, width and length dimensions back at base.
      Click image to view animated gif.
      The iPin Pro attaches to a smartphone magnetically and the better the smartphone's camera resolution the better the results. It can be used as a standalone device also.
      The specs are quite impressive,
      The iPin Pro is a current Kickstarter campaign and pitched at around €68. Anyone interested can check it out here.
      Mike
      • pbacotP
        might be good. I've tried a few iPAD apps that don't have an add-on and found them lacking. It's got to be dependable or it's a waste of time. One such app required zeroing in on all the corners of the room. First you had to find an empty room!
        • Mike LuceyM
          Mike Lucey
          Hi pbacot,
          I’ve also tried out a few iPad apps where one has to zero in on the corners. It was a bit clunky and the results were not that great.
          I take you point about taking pics with furniture in place. I have asked the campaigner about this and will report back with anything I learn.
          Mike
          • jo-keJ
            jo-ke
            looks interessting.
            Does it also creat an SU file in output?
            http://www.zz7.de
            • aadbuildA
              aadbuild
              I purchased a phone that used Project tango, it was cool, unfortunately, google ditched it like a hot potato.... There goes a $1000 dollars arghhh.
              I would be interested in giving it a go.
              Every building designed can be affordable & buildable, to help we built PlusSpec; VDC & BIM for Sketchup
              https://www.plusspec.com
              • K
                kaas
                I'm also looking for a more modern and easy way to do building surveys.
                In my notes I find the IpinPro had some really bad reviews so it wasn't an option for me. I didn't even bother to write down which reviews so better look for yourself. Maybe they have fixed the software by now.
                • B
                  billharis
                  Thanks.
                  @mike lucey said:
                  Hi Guys,
                  I think the iPin Pro will be attractive to anyone that completes building surveys. I don't complete as many as I used to which involvedtwo persons a lot of the time. This device eliminates the need for a second person as the user simply takes photos and extrapolates the height, width and length dimensions back at base.
                  [attachment=3:29agpn6f]<!-- ia3 -->d9adbd1a35869d564c61de14f34ac7f0_original.gif<!-- ia3 -->[/attachment:29agpn6f]
                  [attachment=2:29agpn6f]<!-- ia2 -->fda52533529f7b0b8697cfb1bc76c80d_original.gif<!-- ia2 -->[/attachment:29agpn6f]
                  [attachment=1:29agpn6f]<!-- ia1 -->44100767f597dcda9b2aa3af27e107f4_original.jpg<!-- ia1 -->[/attachment:29agpn6f]
                  [attachment=0:29agpn6f]<!-- ia0 -->b19ef7747f8bc7bd6ab97d1f66fa0690_original.jpg<!-- ia0 -->[/attachment:29agpn6f]
                  Mike
                  • R
                    ramyasri123
                    • D
                      dkbusinesspatron
