    IPin Pro - Ideal for one-man building surveys!
    9 Posts 8 Posters 343.7k Views 8 Watching
    • Mike LuceyM Offline
      Mike Lucey
      Hi Guys,
      I think the iPin Pro will be attractive to anyone that completes building surveys. I don't complete as many as I used to which involved two persons a lot of the time. This device eliminates the need for a second person as the user simply takes photos and extrapolates the height, width and length dimensions back at base.
      Click image to view animated gif.
      The iPin Pro attaches to a smartphone magnetically and the better the smartphone's camera resolution the better the results. It can be used as a standalone device also.
      The specs are quite impressive,
      The iPin Pro is a current Kickstarter campaign and pitched at around €68. Anyone interested can check it out here.
      Mike
      • pbacotP Offline
        might be good. I've tried a few iPAD apps that don't have an add-on and found them lacking. It's got to be dependable or it's a waste of time. One such app required zeroing in on all the corners of the room. First you had to find an empty room!
          Mike Lucey
          Hi pbacot,
          I’ve also tried out a few iPad apps where one has to zero in on the corners. It was a bit clunky and the results were not that great.
          I take you point about taking pics with furniture in place. I have asked the campaigner about this and will report back with anything I learn.
          Mike
          • jo-keJ Offline
            jo-ke
            looks interessting.
            Does it also creat an SU file in output?
            http://www.zz7.de
            • aadbuildA Offline
              aadbuild
              I purchased a phone that used Project tango, it was cool, unfortunately, google ditched it like a hot potato.... There goes a $1000 dollars arghhh.
              I would be interested in giving it a go.
              Every building designed can be affordable & buildable, to help we built PlusSpec; VDC & BIM for Sketchup
              https://www.plusspec.com
                kaas
                I'm also looking for a more modern and easy way to do building surveys.
                In my notes I find the IpinPro had some really bad reviews so it wasn't an option for me. I didn't even bother to write down which reviews so better look for yourself. Maybe they have fixed the software by now.
                  billharis
                  Thanks.
                  @mike lucey said:
                  Hi Guys,
                  I think the iPin Pro will be attractive to anyone that completes building surveys. I don't complete as many as I used to which involvedtwo persons a lot of the time. This device eliminates the need for a second person as the user simply takes photos and extrapolates the height, width and length dimensions back at base.
                  [attachment=3:29agpn6f]<!-- ia3 -->d9adbd1a35869d564c61de14f34ac7f0_original.gif<!-- ia3 -->[/attachment:29agpn6f]
                  [attachment=2:29agpn6f]<!-- ia2 -->fda52533529f7b0b8697cfb1bc76c80d_original.gif<!-- ia2 -->[/attachment:29agpn6f]
                  [attachment=1:29agpn6f]<!-- ia1 -->44100767f597dcda9b2aa3af27e107f4_original.jpg<!-- ia1 -->[/attachment:29agpn6f]
                  [attachment=0:29agpn6f]<!-- ia0 -->b19ef7747f8bc7bd6ab97d1f66fa0690_original.jpg<!-- ia0 -->[/attachment:29agpn6f]
                  Mike
                    ramyasri123
                      dkbusinesspatron
