    Erratic behaviour when trying to create a solid
    2 Posts 2 Posters 1.0k Views 2 Watching
      currang2
      In 2017 Pro I created a non-prismatic but relatively simple volume made up of 4 sided non-parallel shapes, but it wasn't recognised as a solid. All surface were oriented the correct way.
      I then broke the surfaces into triangles. Still not recognised as a solid.
      Then I deleted the diagonals to get back to the original shape made up of 4 sided non-parallel shapes. Suddenly it was recognised as a solid.
      Why. I can't see a logic in this experience.
      I have experienced similar behaviour in the past and gave up on trying to create a solid after spending a lot of time trying to edit the shape as I had tried this time.
      Is this a bug, and can it be fixed or worked around?
      This is the model referred to in the message.
      • BoxB Offline
        It's a bit hard to tell you anything when you give us the solid version, could you try one that isn't showing as solid.
        Technically even this version isn't a solid,it should really be defined and a void surrounded by an infinite nothingness. This is because you have the faces reversed, meaning the shape is inside-out. When viewed in Monochrome you should only see white faces, the blue/grey faces are the back or internal faces.
