    New build
    13 Posts 4 Posters 9.9k Views 4 Watching
    • F Offline
      Futurepast
      Just finished the last of it. Here is what I have....
      Started off with a Corsair Graphite Series 780T Full Tower PC Case – Black. Put in a Corsair CP-9020140-NA HX1200 1200W 80 Plus Platinum High Performance Power Supply. Then for my MOBO went with the ASRock X299 GAMING K6 Fatal1ty LGA 2066 Intel X299 SATA 6Gb/s USB 3.1 USB 3.0 ATX Intel Motherboard. Followed with a Intel Core i7-7820X Processor (I didn’t think the extra 500 bucks was worth the upgrade. Then to cool it I went with Corsair Hydro Series H115i Extreme Performance Liquid CPU Cooler , Black. For the RAM I started with CORSAIR DOMINATOR Platinum Series 32GB (2 x 16GB) DDR4 DRAM 3000MHz C15 memory kit (CMD32GX4M2B3000C15) of witch I can fill 6 more slots later. For my Vid Card I went with 2 each EVGA GeForce GTX 1080 Ti FTW3 GAMING, 11GB GDDR5X, iCX Technology - 9 Thermal Sensors & RGB LED G/P/M, 3x Async Fan Control, Optimized Airflow Design Graphics Card 11G-P4-6696-KR in SLI and of course Corsair K55 Gamming keyboard and mouse with RBG programmable and for total flight control two Guillemot Thrustmaster T.16000M Fcs Joysticks And don’t want forget my memory, Samsung 850 EVO 500GB 2.5-Inch SATA III Internal SSD (MZ-75E500B/AM) for my operating system Windows 10, and two Western Digital 1T drives for memory. The monitor is an ASER P8278 LCD. And I went with the Occulas VR just because 😄
      Think I’m a fan of Corsair? And I can expand and upgrade!
      • jujuJ Offline
        juju
        Enjoy the new machine!
          That'll definitely run Minecraft.
          • F Offline
            Futurepast
            I just wanted one last super build. Getting to old to worry. And yes I do a lot of gaming but I find that a gaming computer is great for rendering.
            • N Offline
              numerobis
              Sorry, but why a SATA-SSD?
              • F Offline
                Futurepast
                It came down to a choice between SATA III standard and backup solutions or modifying bios and using custom drivers.... 😐
                • N Offline
                  numerobis
                  I don't understand... why would you need a modified BIOS and custom drivers?
                  • F Offline
                    Futurepast
                    When I was looking, most of the larger drives were server based, and would not boot from them, or I had to buy an adapter - a spine. What ever. I wanted simplicity. Later I might go SAS and my drive would still work. What else would you do?
                    • N Offline
                      numerobis
                      Why SAS? But even then... where is the problem to boot from a M.2 drive? You would need an external SAS controller anyway with this board. I think i still don't get it.
                      • F Offline
                        Futurepast
                        When I start a project I plan everything out. I put together the plan then built it. I couldn't afford to build it all at one time. I spent 4 months collecting parts, before the build 😉 At the time of my "planing" this is what I saw:
                        "SSD drives offer the best experience when they are used as the root or boot drive. The problem is that the existing Windows software has an issue with many drives booting from the PCI-Express bus rather than from SATA. This means that having an M.2 drive using PCI-Express while fast won't be the primary drive where the operating system or programs are installed. The result is a fast data drive but not the boot drive."
                        You have to remember that I'm old, self taught, and what I deal with normally is wood 😳
                        • jujuJ Offline
                          juju
                          My laptop has a 512GB m.2 PCIE drive for OS + progs, with a SATA SSD for storage.
                          It starts up fast and has not skipped a beat in the 6 months I've had it.
                          • N Offline
                            numerobis
                            I'm using a X99 system with PCIe M.2 SSD (AHCI) as boot drive since 2015 (win 7).
                            There were some AHCI M.2 drives where you couldn't boot from (3-4 years ago) and there have been some limitations for a while with NVMe based drives (instead of AHCI) and Win 7, but even these should have been fixed i think
                            https://support.microsoft.com/en-us/help/2990941/update-to-add-native-driver-support-in-nvm-express-in-windows-7-and-wi
                            But with X299 boards and Win 10 there definitely shouldn't be any problem booting from NVMe M.2 SSDs. So i don't know where you got this info from and how old this article was, but it's not the case anymore.
                            (And the ASRock X299 GAMING K6 Fatal1ty comes with 3 PCIe x4 M.2 ports, which wouldn't make any sense if you couldn't use M.2 as a boot drive.)
                            But nice system overall 😉
                            • F Offline
                              Futurepast
                              Thanks for the info! With every day comes something new to learn 😄
