    Section Path
    4 Posts 3 Posters 825 Views 3 Watching
      alanfarkas
      Hi guys,
      Newbie (sorta) here. I also use Rhino (and Vectorworks).
      When I draw a 2D Drafting of a section for a room, I will draw it so it begins and terminates in wall openings (even if they are not across from one another.)
      This means on the plan view, I will show a Section Line that does a little jog so it goes through the openings.
      Is there a way to accomplish this is 3D in SKP - to create a section plane that jogs? Or should I just plan on having the straight section planes when making my cuts in SKP?
      Thanks, and thanks in advance for all my future questions as I learn....
        Without the golden rule to post an image of what is wanted! πŸ˜„...
        Or better an skp file (in Save as V6 for a more large audience) ! ...
        I don't know the meaning of jog! 😳
        So no idea of what is asked! πŸ˜„
        • pbacotP Offline
          Funny, sometimes I avoid the openings cause I don't want to draw them! (hopefully with model that's no issue). Just on first glance, the only way I can think is if you group the halves of the building separately and put a section in each group. Of course that may go against your model strategy. Not saying it's the only way but...
            About funny sections you can use the Visuhole by FredoSix! πŸ˜‰
