    Sketchup-RBC智能坐标轴(Intelligent reset axes)
    2 Posts 2 Posters 1.8k Views 2 Watching
    • L
      lghtlmy
      RBC智能重置坐标轴可以智能更改单个模型的坐标轴,也可以批量更改模型的坐标轴,更是可以更改嵌套模型的坐标轴。
      The RBC intelligence reset axes can intelligently change the axes of a single model, or change the axes of a model in bulk, or change the axes of a nested model.
      http://ww3.sinaimg.cn/large/0060lm7Tly1fp6vsyswp7g30nw0c97wj.gif
      伴随着大家的期待,RBC智能重置坐标轴工具应运而生!
      设计师尤其是新手设计师,在面对大量模型却发现模型本身的坐标轴并没有与模型本身对齐时,无从下手,建模的效率也往往是低下的。我们可以手动去更改模型本身的坐标轴,但是嵌套的模型量一旦很大的话,
      手动更改模型坐标轴就会变的更加复杂。
      http://ww1.sinaimg.cn/large/0060lm7Tly1fp6vykqpxwg30nw0c9u0z.gif
      With the expectation of everyone, RBC intelligent reset coordinate axis tools emerge!
      Designers, especially novice designers, are unable to do so when confronted with a large number of models but find that the axes of the model itself are not aligned with the model itself, and the efficiency of modeling is often low. We can change the axis of the model itself manually, but once the number of nested models is large,
      Manual changes to the model axis make it more complex.
      http://ww3.sinaimg.cn/large/0060lm7Tly1fp6w29z3srg30hs0aj0vp.gif
      http://ww3.sinaimg.cn/large/0060lm7Tly1fp6w78kcxng30nw0c94qr.gif
       RBC智能重置坐标轴的出现,完美的解决了这些问题,也是有洁癖的设计师的福音,它可以智能更改单个模型的坐标轴,也可以批量更改模型的坐标轴,更是可以更改嵌套模型的坐标轴。
      The advent of RBC's intelligent reset axes solves these problems perfectly, and is a boon to neat designers who can intelligently change the axes of a single model, or change the axes of a model in bulk, or change the axes of nested models.
      简介
      处理范围
      是处理选择的组件还是所有的组件。
      矫正次数
      矫正算法是基于数学算法。
      有时候不能一次到位。需要多次迭代矫正。
      原点位置
      矫正以后,原点所处的位置是中心还是底部中心。
      是否处理嵌套组件/群组
      由于插件的开发需要一定的时间和成本,所以综合考虑,此插件为收费插件,实行一机一码制,插件费用仅收取36元人民币,(6美元)
      Introduction
      Scope
      Is it the component to process the selection or all the components.
      Number of corrections
      The correction algorithm is based on mathematical algorithm.
      Sometimes you can't get there at once. Multiple iterative corrections are required.
      Original location
      After correction, the origin is in the center or the bottom center.
      Processing nested component groups
      Because the development of the plug-in needs certain time and cost, so the comprehensive consideration, this plug-in charge plug-in, a system of one-machine, plug-in charge only 36 RMB(6$)
      家对于RBC有任何的问题,欢迎大家加入RBC官方QQ群和微信群进行讨论。
      QQ群号为:397192573
      微信公众号:RBC联盟
      Home to RBC has any questions, welcome to join the RBC official QQ group and micromessaging group for discussion.
      QQ Group number: 397192573
      Micromessaging Public: RBC 联盟(Alliance)
      Facebook group: https://www.facebook.com/groups/RBC.Sugar
      Facebook组: https://www.facebook.com/groups/RBC.Sugar
      • R
        rv1974
        百花齊放,百家爭鳴!
        翻译你的工具,如果你想要我的钱
        提前致谢
