    MSPhysics with Dynamic Components
    extensions
    1 Posts 1 Posters 2.2k Views 1 Watching
    • M
      mugglejack
      Can a MSPhysics joint be dynamically positioned with a point in a dynamic component that moves (as the component is changed)? Example follows.
      First image shows a motor joint (blue) attached to one end of a dynamic component (yellow). I joined these together as I drew the mechanism. The red cylinder is a fixed mesh.
      Second image shows the dynamic component changed to make it longer - so what I want to do is to make the motor joint move to the new position of the end of the dynamic component without having to manually move the motor.
      SKU file attached.
      Thanks, Graham.
      dcCrankAssembly.skp
