    Section Fill Problem 2018
    3 Posts 2 Posters 1.6k Views 2 Watching
    • J
      JakeMM
      It keeps filling the wrong bits!
      The building doesn't even have a roof drawn, and as it's early in the design, it's very simple geometry.
      Can't get my head around this! I can't even work out why it works on part of the building, but not the other rooms?!
      Any ideas??
      Video of the problem here:
      https://www.dropbox.com/s/tji13ur6qodkz4p/Problem.mp4?dl=0
      • J
        JakeMM
        Update: Ok, it looks to be that because it was a simple model, that's why Sketchup got confused.
        Once I'd started adding some internal walls, everything magically worked as it should do!
        • pbacotP
          Without seeing it. That's what I figured. You can always just add a temporary flat roof or something. SU doesn't know a house from anything else. It's really just set to find some sort of negative space it seems.
