    Way Too Long For Exported Images!
    11 Posts 4 Posters 1.9k Views 4 Watching
    • Joe WoodJ Offline
      Joe Wood
      The last week + I've been having 15 to 20 second exporting jpg at 6000 pix wide, taking way too long. With Shadows off! Can you tell what's going on by the cpu, or is it something else I should look for?
      Joe Wood
      woodsshop.com/
      • boofredlayB Offline
        boofredlay
        Did you by chance check the Anti-alias box? That will slow an export to a crawl.
        • Joe WoodJ Offline
          Joe Wood
          Nope, but good choice!
          Joe Wood
          woodsshop.com/
          • Joe WoodJ Offline
            Joe Wood
            tried turning off Use Fast Feedback and Use Hardware Acceleration and Max Tex Size and none helped.
            Joe Wood
            woodsshop.com/
              boofredlay
              Hmm, not sure what is going on. Have you restarted your computer in case there is something running in the background you are unaware of?
              • Joe WoodJ Offline
                Joe Wood
                Yes I sure have Boo.
                Joe Wood
                woodsshop.com/
                  JakeMM
                  Couple of things I can think of:
                  Is this just on one particular model?
                  If you try an older version of Sketchup, does this change anything?
                  Are the fans on the computer suddenly a lot louder? Is the computer a lot hotter than it usually is?
                  • Joe WoodJ Offline
                    Joe Wood
                    No this is with every model I've been working on the last few weeks Jake, and I don't have any versions older then 2015.
                    I can't hear very well but I don't think the fans are louder.
                    Joe Wood
                    woodsshop.com/
                      Derek Edison
                      Are you applying a style? Some of the heavily customized styles we use that have watermarks, etc. will dramatically increase our export times.
                      • Joe WoodJ Offline
                        Joe Wood
                        It's the same stock style I always use.
                        Joe Wood
                        woodsshop.com/
                        • Joe WoodJ Offline
                          Joe Wood
                          does this cpu shot tell you anything?
                          this took 25 seconds to export at 6000 pix wide, and the program seems to freeze and this white box appears on the screen and the little white box lower left ..
                          Joe Wood
                          woodsshop.com/
