    Line Extensions Not Translating to LayOut 2018
    Scheduled Pinned Locked Moved LayOut Bug Reporting
    layout
    5 Posts 3 Posters 11.9k Views 3 Watching
      MickC01
      I'm noticing that the only way to see line extensions and endpoints (SU style settings) now in LO is to view inserted scenes in "raster". Change the views to vector or hybrid, they vanish. Also when printing they still seem to vanish.
      I hope this gets fixed soon as I have developed some of my own styles in which I use line extensions. Would dearly love to again be able to use hybrid and vector again....Mick C
        It has been reported and recognized by the LO team as a bug they are working on.
          MickC01
          Thanks, Dave πŸ˜„
            jnrassi
            Having the same problem. Line extensions disappear when using Hybrid render. Is there a fix or workaround for this?
              As I wrote before, the issue is known to the LO team and it's in the pipeline for a fix. As a work around, you could use Raster rendering and export at highest output quality or you could manually make extensions. Neither is ideal but until a fix is released, there's not much of an option.
