    [Plugin]Ithil Render Tools 3.01 for V-ray 3.*
    1 Posts 1 Posters 965 Views 1 Watching
    • ithilI Offline
      ithil
      Hello everybody. I finally finished the new version of the plugin. Now it is compatible with v-ray 3. * version.
      Forum topic for the old version, compatible with v-ray 2.*
      This plugin was called to help you with this routine work.
      Most of simple materials are now create with just one click. Moreover, all similar materials having different color can be grouped and tagged and you can work with them using just one button.
      For example: all plastic toys in kids room , all books, pencils on the desk, all magazines and etc. Imagine if you have to set up each of these materials?
      Now, with this plugin you can automatically set them up without any problems!
      Download from Sketchucation PluginStore
      Download from SketchUp Extension Warehouse
      Watch the explaining video
      **SU Version - Developed on SU 2017, checked in SU 2018.
      This version should be compatible with Windows and Mac OS X. But I do not have the opportunity to test on mac OS.
      Supported render: V-ray Version - 3.*
      Not support V-ray Version 2.***
      For v-ray 2.* you can use the old version
      • Added compatibility with v-ray 3
      • Camera Clipping Plane
      • Convert Displacement to Bump
      • Turn off Displacement
      • Size of texture by suffix
      • Cast shadow of
      • Change the textures file name - in one click changes all textures in complex material. Textures should be in the same folder
      • Change GI multiplier
      • Material Layers list
      • Mark Standart Material
      • Mark V-Ray 2 Material
      • Mark Emissive Material
      • Copy V-ray Fur options
      • Hide V-ray objects on Hiden Layer
      • Convert (ST) » {ST} tag
      • Fix Material Name
      • Change 'Size' in Map
      • Past HEX color in Diffuse,Reflect,Refract or Fog color
      • Copy V-ray material
      • Past V-ray Diffuse
      • Past V-ray attribute - works with a group of materials through tags
      • Rename material - Add Tag, Add Prefix, Add Suffix
      Right-click mouse menu
      • Change Size in Map
      • Past HEX color
