    Section Cuts - Color by Layer option ?
    extensions
    1 Posts 1 Posters 1.9k Views 1 Watching
      Alanwhughes
      Does anybody know of a plugin in existence, that enables section cut lines to display (and export) either by material color, or layer color ?
      I can get lines that are not section cut to display as color by material, and I need a way of this color data being transposed into either the 'create group group from slice' option, or the export to 2D graphic, when a section is cut and aligned in true parallel projection.
      It doesn't really matter if this plugin works on the material color of a group, or the layer color it is on, as I can change workflow to suit if only one is possible.. I have recently got into the habit of using layer color to 'paint' the model rather than materials, as it helps me keep groups on correct layers, and I have found textures tend to slow down larger models..
      Cheers,
      Alan
