    LOAD ERRORS - Extentions
    extensions
    3 Posts 3 Posters 3.2k Views 3 Watching
    • I
      iborov
      Dear community, I've been using sketchup for some time now. I had SketchUp 8 with some plugins and they were working fine but now I have SektchUp PRO 2017 and they cannot load.
      I've tried uninstalling and installing Sketchup, tried deleting the plugins from the folder. Uninstalling them from the extention manager but still nothing happnes.
      Here is the LOG file:
      Error Loading File C:/Users/fur03/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/Fredo6_!LibFredo6/top_LibFredo6.rbe
      Failed to read RBE/RBS file.
      Error Loading File Fredo6_!LibFredo6.rb
      Error: #<NameError: uninitialized constant LibFredo6_Loader::LibFredo6>
      C:/Users/fur03/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/Fredo6_!LibFredo6.rb:63:in process' C:/Users/fur03/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/Fredo6_!LibFredo6.rb:70:in module:LibFredo6_Loader'
      C:/Users/fur03/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/Fredo6_!LibFredo6.rb:28:in <top (required)>' Error Loading File Fredo6_Curviloft.rb Error: #<TypeError: can't convert nil into an exact number> C:/Users/fur03/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/Fredo6_!LibFredo6.rb:79:in -'
      C:/Users/fur03/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/Fredo6_!LibFredo6.rb:79:in <top (required)>' C:/Program Files/SketchUp/SketchUp 2017/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:54:in require'
      C:/Program Files/SketchUp/SketchUp 2017/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:54:in require' C:/Users/fur03/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/Fredo6_Curviloft.rb:47:in module:Fredo6'
      C:/Users/fur03/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/Fredo6_Curviloft.rb:26:in <top (required)>' Error Loading File Fredo6_JointPushPull.rb Error: #<TypeError: can't convert nil into an exact number> C:/Users/fur03/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/Fredo6_!LibFredo6.rb:79:in -'
      C:/Program Files/SketchUp/SketchUp 2017/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:54:in require' C:/Users/fur03/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/Fredo6_JointPushPull.rb:47:in module:Fredo6'
      C:/Users/fur03/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/Fredo6_JointPushPull.rb:26:in <top (required)>' Error Loading File Fredo6_RoundCorner.rb Error: #<TypeError: can't convert nil into an exact number> C:/Users/fur03/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/Fredo6_!LibFredo6.rb:79:in -'
      C:/Program Files/SketchUp/SketchUp 2017/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:54:in require' C:/Users/fur03/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/Fredo6_RoundCorner.rb:47:in module:Fredo6'
      C:/Users/fur03/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/Fredo6_RoundCorner.rb:26:in `<top (required)>'
      Error Loading File C:/Users/fur03/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/su_advancedcameratools/actloader.rbe
      Error Loading File C:/Users/fur03/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/su_dynamiccomponents/ruby/dcloader.rbe
      Error Loading File C:/Users/fur03/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/su_sandbox/sandboxmenus.rbe
      Error Loading File C:/Users/fur03/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/su_trimble_connect/boot.rbe
      Error Loading File C:/Users/fur03/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/su_webtextures/webtextures_loader.rbe
      I've tried to search on the forum similar thread but couldn't find a solution.
      Can you help me?
      • BoxB
        Did you try to copy your plugin folder over from an earlier version?
        • mariochaM
          mariocha
          Iborov
          Did you find a solution?
          One of my trainees is having the same problem on win 7.
          Fresh new installation, no other plugins than SU.
          Need help. ❗
          %(#008000)[Mario C.
