    Is JointPushPull in SketchUp 2018 more limited?
    extensions
    2 Posts 2 Posters 3.9k Views 2 Watching
    • I
      IntelCoreDuo
      My colleague who uses SU 2018 needed to generate some complex shapes, but was unable to do so with JointPushPull as it for some reason lacked the option to enable or disable "project the shape on a plane" (flatten the new face of the extruded surface). Also, the option to generate as group was gone. All others settings were seemingly in place, even though it looked a bit different.
      After installing 2017 like I use, JointPushPull worked fine. Did she install wrong version of the plugin, is SU 2018 the problem, or am I missing something?
      • A
        allenmeyer
        I'm having the same problem with SU2019 Pro. Does anyone have insight as to where the JointPushPull 'project on a plane' has gone to?
