    Cut a hole in a surface with the outside of a component
    2 Posts 2 Posters 552 Views 2 Watching
    • M
      Mrvain77
      Hi!
      I´m looking for an easy way to cut out a hole in a surface exactly by the outside of an component. Here is the project, https://www.dropbox.com/s/91wot47w8cehkad/Bj%C3%B6rlanda%20kile.skp?dl=0 , and i am doing this type of project a lot.
      If you look in the project you can se that i have a big existing ground which is from a drone an then i have a component for some new ground around a new house. I want an easy way to melt this 2 together, and of course, the new ground should replace the existing ground. :slight_smile:
      I've tried a lot of different things but i cant find any easy way, so can anyone help me?
      • A
        alpro
        Use the stamp tool to cut a hole in the terrain, then you'll have to clean up the trees, see pic.
