    Laptop for modelling
    6 Posts 3 Posters 1.8k Views 3 Watching
    • D
      Dprince
      I currently use a 2012 macbook pro and wanting to upgrade to something much faster with better performance. less program crashes etc.
      I believe right now my budget is up to $1000USD. I use Vray and sketchup for modelling and i may use 3dsmax from time to time.
      Can anyone recommend some laptops please much appreciated.
      • N
        nlipovac
        I think any gaming laptop would do. I got older one Asus G750jz and it serves me well.
        Go for i7, min 16GB RAM, SSD (not smaller than 256GB) + HDD and best Nvidia GPU you can afford. Buy one with Thunderbolt 3 so you could, later on, buy an external case with full-sized desktop GPU and speed up your GPU+CPU rendering, if this $1K would not get you good GPU. You could go with 15" display and add one larger desktop monitor (24"+).
        • sketch3d.deS
          sketch3d.de
          Windows or macOS?
          Modeling performance relies on CPU, CPU, CPU (single thread), a halfway recent high-clocked intel Core i5/i7 is fine.
          For the GPU and if for Windows strive for a medium-sized nVidia GT(X) 1050/1060 (or the predecessors 950/960).
          8-16 GB RAM (depends on model size and a rendering requirement as well as if an upgradeable or closed device) should suffice. A SSD as the system medium is recommended, if big enough a second HDD is often not required.
          • D
            Dprince
            @sketch3d.de said:
            Windows or macOS?
            I was thinking about windows because everybody says windows is the better option
            • sketch3d.deS
              sketch3d.de
              depends, if you are accustomed to Mac OS and have a lot of applications as well as knowledge migrating to another operating system should be thoughtful evaluated.
              But Windows hardware is a bit cheaper (besides high-end) and options concerning available CPUs/GPUs broader.
              Looking for a 'Gamer' notebook is regularly a good recommendation because a dedicated graphics card intergrated. A system of the big three (HP, Lenovo, Dell) will typically work, Asus and Acer might be alternative options.
              Lots of notebook reviews here.
              P.S.: don't full-quote
              • D
                Dprince
                Thanks for the help and start searching
