    Materials changes names.
    1 Posts 1 Posters 536 Views 1 Watching
    • J
      jonorman
      Hi..
      May not be the right place to post this but I`ll try anyway..
      So i have this model assembly put together of several sub-assembly`s using either X-ref tools or/and the Cross reference Organizer plugin.
      Here is the thing:
      In one of the sub-models i paint it using Thru-paint with custom names on the materials I make ie. "structural wall_001" and then I paint the walls.
      When I save the model everything is ok and dandy πŸ˜„
      But after I ref this model in to the main model things start to change.. If i have the main model open, and open one of the sub-models`s, the materials change names to "mat001, mat002, mat003 and so on.
      If i close everything and reopen the one of the sub-models everything is ok again.. why is this ???
      Can SU not handle the names of the materials if i have 2 SU windows running at the same time ???
      So, anyone know why this happens ???
      Thank you πŸ˜„
