    Convert image to halftoned triangular perforation ??
    6 Posts 3 Posters 2.6k Views 3 Watching
    • C
      cuttingedge
      Hi everyone, Im faced with a challenge of creating something like the image...
      halftone perforation on panel...
      a halftone design on perforated panels...
      Creating it in Sketchup should be very easy.. But making the vector from the image is a challenge..
      I cant generate this vector from my image...
      Ive tried looking for softwares that can do that but most that i tried cant do this exact thing.. Would truly appreciate if anyone can help...or suggest a solution...
      Edd
      • pbacotP
        You tried? https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&cad=rja&uact=8&ved=0ahUKEwiqsoWsysbXAhXDKGMKHaBNCtUQFggoMAA&url=https%3A%2F%2Fvectormagic.com%2F&usg=AOvVaw1yFjtUMiIpMe7FvZwL38Nf
        • HornOxxH
          HornOxx
          ... the free tool Inkscape could probably do a good part of the job? Itยดs tracing tool is not too bad.
          maybe you can get the desired shapes this way to fill these shapes with your triangulated pattern then. - The now created result(s) should provide a good basis for a final second vectorization ? ...
          This topic is so important for me as well, so please keep posting how you come along ๐Ÿ˜‰
          https://www.youtube.com/watch?v=U248SJcxRWA
          https://www.youtube.com/watch?v=R6dgW5J0Osw
          https://inkscape.org/en/
          Btw: this is such a great render! - is it yourยดs or just an example?
          @ pbacot: ๐Ÿ‘ I have placed your interesting link at my favorites
          never trust a skinny cook
          • C
            cuttingedge
            Sure i will...
            I found one good site that makes halftone vectors of images.. I just dont see the triangular perforation pattern option.. and they come with watermark in the output...but works well...
            https://halftonepro.com/app#
            Once i got the image halftoned, then vectorization should be an easy job
            BTW, I failed to mention the above is the famous DGJ+NAUโ€™s bank building for Raiffeisen in Zurich...not my project...
            • HornOxxH
              HornOxx
              ... thanks Cuttingedge!
              just an other video link which seems to be very close to what you (we) are looking for ๐Ÿ˜‰
              Up from minute 4 it is getting interesting because the tutorial-presenter is creating his own custom pattern obviously with ease ๐Ÿ˜„ I hope to find the time to test this procedure soon and if i succeed i will report here also ๐Ÿ˜„
              • C
                cuttingedge
                Thanks there Hornoxx.. Really useful.. I havent tried inkscape, Now for sure I will..
                I also found a quick dedicated app for this purpose which is very easy to use.. its called halftoner from
                http://jasondorie.com/page_cnc.html. This is mainly used for CNC pattern production which generates high res image or vector (dxf)
                I was able to generate this image of my city's skyline..generated  by Halftoner v1.7
