    Activate last selection
    5 Posts 4 Posters 2.3k Views 4 Watching
    • TNTDAVIDT Offline
      TNTDAVID
      Hello everyone! ☀
      Can I activate a previous selection in a method?
      For example:
      • I select a piece of furniture in SketchUp.
      • I activate a method that selects handles that are sub-components.
      • Subsequently, it disables the furniture selection.
      • Another method changes the Handles.
      • Can we then reactivate the furniture selection?
      If so, how should I proceed?
      Thank you
      • K Offline
        ktkoh
        I am not an accomplished coder but it seem to me that if you think the user is going to need access to the sel save it as an array at the first then it can be reused.
        Keith
          slbaumgartner
          Seems to me that ktkoh is right. Make an Array using #to_a to remember the contents of the current selection. Then later use Selection#clear! and Selection#add to put the contents of the Array back into the Selection.
          • Dan RathbunD Offline
            Dan Rathbun
            There might be a plugin out there called "Selection Memory" or similar.
            I'm not here much anymore.
            • TNTDAVIDT Offline
              TNTDAVID
              Thank you for your help! ☀
              I will analyze the Selection Memory Plugin and post the method if I find it.
