    Redraw a dynamic component
    19 Posts 2 Posters 5.0k Views 2 Watching
    • TNTDAVIDT Offline
      TNTDAVID
      **Hello, 😄
      The code below redraws the instance 0 named with the definition "BOX".
      model = Sketchup.active_model
      model_definition = model.definitions
      model_def = model_definition['BOX']
      $dc_observers.get_latest_class.redraw_with_undo(model_def.instances[0])
      How to redraw all the instances being selected without taking their definitions into account?
      Thank you
      David**
        Something like
        Sketchup.active_model.selection.grep(Sketchup;;ComponentInstance){|i|
          next unless i.definition.attribute_dictionaries["dynamic_attributes"]
          $dc_observers.get_latest_class.redraw_with_undo(i)
        • TNTDAVIDT Offline
          TNTDAVID
          I get the following error message with your TIG example:
          Error: #<ArgumentError: wrong number of arguments (1 for 0)>
          <main>:2:in attribute_dictionaries' <main>:2:in block in <main>'
          <main>:1:in each' <main>:1:in grep'
          <main>:1:in <main>' -e:1:in eval'
          nil
            Sorry, I adjusted the () to []. I can't actual test this code as I type it !
            • TNTDAVIDT Offline
              TNTDAVID
              Thank you TIG! 😄
              This solution will give me even more possibilities in the future with the dynamic components. 👍
              • TNTDAVIDT Offline
                TNTDAVID
                **I found with some tests that it is not possible to add dynamic attributes to neutral components.
                The component must have at least an existing attribute for it to be possible to add attributes in ruby.
                If not, we have this error message:
                Error: #<NoMethodError: undefined method []' for nil:NilClass> <main>:1:in block in <main>'
                <main>:in each' <main>:in grep'
                <main>:in <main>' -e:1:in eval'
                nil
                The goal is certainly to protect the creation of dynamic components, which is only available in Pro version of SketchUp?**
                  Without us seeing your code it's impossible to say what raises your error message.
                  Perhaps adding an extra test before testing for the DC attribute dictionary [] entry
                  as the first test will stop it failing, since the DC dictionary can't be tested for without the existence of the attribute dictionaries entry.
                    You can create a new dictionary thus
                    some_definition.set_attribute("dynamic_attributes", "test", "1")
                    p some_definition.attribute_dictionaries["dynamic_attributes"]
                    • TNTDAVIDT Offline
                      TNTDAVID
                      **Sorry TIG for not having specified the method used.
                      I tried these 2 methods:
                      i.set_attribute 'dynamic_attributes','teste', '1'
                      i.set_attribute("dynamic_attributes", "test", "1")
                      i.attribute_dictionaries["dynamic_attributes"]
                      None of the 2 solutions work on a component without dynamic attributes.
                      nil
                      But these 2 solutions work on components already have dynamic attributes.**
                        The attributes belong to the instance's defintion NOT the instance.
                        You mess up trying to set things to the instance, NOT the definition !
                        Try substituting something like...
                        i.definition.set_attribute('dynamic_attributes', 'teste', '1')
                        Please learn the difference between a definition and its instance !!!!!
                        • TNTDAVIDT Offline
                          TNTDAVID
                          This still does not work for components without attributes:
                            WTF !
                            You really must learn basic principles...
                            consider this:
                            ###next unless i.definition.attribute_dictionaries["dynamic_attributes"]
                            The added ### skips the check for the dictionary [ which you do NOT need ! ]... so IF a definition does NOT have that dictionary set then it makes it anyway !!!!!!
                            • TNTDAVIDT Offline
                              TNTDAVID
                              **OK TIG, I understand!
                              The Ruby is very wide and has many instructions such as:
                              !,&&,||,and,box,else,elsif,eql?,equal,if,then,not,gold,require,unless,wheen,true, false...
                              I had not yet read "unless".
                              I realize that it takes many years of Ruby to totally understand him master it.
                              As I learn according to my needs, this undoubtedly slows down my general understanding of ruby.
                              Promised, next time I would make more effort with your examples before publishing it does not work. 😉
                              Ps: Your solution works wonderfully TIG
                              Thanks a lot for your help.
                              David**
                              • TNTDAVIDT Offline
                                TNTDAVID
                                **Hello, ☀
                                I now want to refresh the visible dynamic components.
                                If not, the answer must be "nil".
                                The methde below works for components that are not nested:
                                m=Sketchup.active_model;
                                s=m.selection;
                                m.definitions.each{|d|s.add d.instances if d.name=~/#{"BOUTON"}/}
                                s.grep(Sketchup;;ComponentInstance){|i|
                                next if i.hidden?
                                Oddly if the components with the "BOUTON" definitions, are nested in another component, they will be considered as visible even if they are hidden.
                                Do you know what is the problem?
                                Thank you**
                                  Please stop adding entities into the selection.
                                  What happens if it already contains some selected entities ?
                                  You haven't cleared it ??
                                  Also these additions might not be in the current context and cause various issue down the line...
                                  Simply create an empty array and add entities to that if they meet a certain test.
                                  e.g.
                                  def handlesCI(ents)
                                    array = []
                                    ents.grep(Sketchup;;ComponentInstance).each{|e| ### collect only visible instances
                                      next unless e.visible?
                                      array << e if e.definition.name =~ /#{"HANDLES"}/
                                      handlesCI(e.definition.entities) ### repeat for nested entities in visibles
                                    array.each{|i| ### process this array of instances
                                  • TNTDAVIDT Offline
                                    TNTDAVID
                                    **Your method works TIG, but it does not keep the "Handles" definitions selected.
                                    The goal is to update all Invisible Handles, then select any definition "Handles" without visibility restrictions.**
                                    • TNTDAVIDT Offline
                                      TNTDAVID
                                      **Here I am in a paradox!
                                      If I apply your TIG method, the handles selected in Method 2 will also be redrawn.
                                      def methodeTIG(ents)
                                          sel = Sketchup.active_model.selection
                                          array = []
                                          methodeTIG(e.definition.entities) ### repeat for nested entities in visibles
                                      def methode2(ents)
                                          ents.each do |e|
                                          if e.is_a? Sketchup;;ComponentInstance
                                          sel.add e if e.definition.name=~/#{"HANDLES"}/
                                          methode2(e.definition.entities)
                                      def methode_end
                                          methodeTIG(instances)
                                          methode2(instances) ### The handles of this method are drawn by the methodTIG!
                                      How can I avoid this?
                                      Thank you**
                                      • TNTDAVIDT Offline
                                        TNTDAVID
                                        **I solved the problem of my previous post!
                                        Now, I'm facing another problem that is much more difficult to solve.
                                        The code below adds an attribute to all the "Handles" definitions that are visible in the components being selected.
                                        def handlesCI(ents)
                                            ents.each do |e|
                                            sel.grep(Sketchup;;ComponentInstance){|i|
                                            next unless i.visible?
                                            i.set_attribute 'dynamic_attributes','attribut', '1'
                                        This method does not work to refresh only visible components.
                                        def handlesCI(ents)
                                            ents.each do |e|
                                        I need your help to understand the problem.
                                        Thank you
                                        David**
                                        • TNTDAVIDT Offline
                                          TNTDAVID
                                          **I ended up bypassing the problem by selecting a different definition than "handles" in method 2.
                                          I asked to select the IKEA definition, which corresponds to the furniture that contains the facades and the handle inside.
                                          def ikeaCI(ents)
                                              ents.each do |e|
                                              sel.add e if e.definition.name=~/#{"IKEA"}/
                                              ikeaCI(e.definition.entities)
                                          This is possible because I specified the definition of the highest components of the hierachie.
                                          Is it possible to select the highest components of the hierarchy without specifying the name of that definition?
                                          Thank you TIG for your method that allows me to redraw the visible handles. 👍**
