    [Plugin] Souvenir - v2.2b - 07 Apr 24
    34 Posts 10 Posters 27.3k Views 10 Watching
    • fredo6F Offline
      fredo6
      The information on Souvenir is maintained on the Plugin Home Page of Souvenir. This is also where you can download the RBZ file.
      • LibFredo6: v14.3 or above
      • Usage: Free under SCF License
      If you land on this page and are unfamiliar with how to install Sketchup Extensions such as LibFredo6 or how to register on Sketchucation, please watch this video or refer to the Plugin page of LibFredo6.
      Fredo6 Souvenir is a utility plugin for Sketchup providing a few productivity tools, currently:
      1. Infinite list of previously loaded models, whereas Sketchup has a limit to 9
      2. Task List a la GoogleKeep, stored by model and at the level of Sketchup (across versions)
      3. Quick access to the Plugin Directory(ies) of the Sketchup environment
      4. Favorites, that is the custom configuration of files, actions and URL links, to be recalled or executed in one click
      HISTORY OF MODELS
      TASK LISTS
      FAVORITES
      PLUGIN FOLDERS
      Fredo6 Souvenir - User Manual - v1.5 - Nov 2017.pdf
      Licensing of Souvenir
      Souvenir is licensed with the new SCF License model of Sketchucation, which is distributed with the Sketchucation Extension Store, as of version 3.1.
      The license is COMPLETELY FREE. It is however necessary to activate all features of Souvenir, which are limited when not licensed (history of 9 models, task list with 4 tasks max).
      All details on licensing Souvenir are described in the PDF documentation above.
          Anton_S
          Fredo,
          Thank you very much for developing this licencing system! It would be essential for many plugin developers in the future, including me.
          Regards,
          Anton
            bharralure
            2017-09-27 12_17_46-Historique des modéles Sketchup.pngBonjour Fredo,
            Après avoir installer "LibFredo6v7.7e", j'ai installer "Fredo6_Souvenir" sous SU Make 2017.
            J'ai le fichier "SCF_Purchased_Licence_Souvenir_Free" mais ne pas le valider.
            Quand je clic le bouton "Licence...", ce n'est pas la boîte de dialogue de la licence qui s'ouvre, mais celle dont je joins une capture d'écran.
            Merci pour de l'aide.
            • fredo6F Offline
              fredo6
              You need to install SCFLicense itself, which is part of Sketchucation ExtensionStore v3.1.3.
              ExtensionStore provides also a cool way to autoinstall plugins in one click and manage them afterwards.
              Fredo
                bharralure
                Merci pour la réponse rapide.
                Je n'utilise pas SketchUcation pour l'installation automatique des plugins, préférant le faire manuellement pour conserver le fichier ".rbz" original.
                Je viens donc de déroger à "ma règle" et d'utiliser ExtensionStore avec succès, et de constater qu'un fichier est automatiquement crée sur mon disque dur en : C:/User/Name/AppData/Local/SCF Licences.
                Donc tout fonctionne.
                Il ne me reste plus qu'à découvrir toutes les subtilités de Souvenir.
                Encore merci.
                • mariochaM Offline
                  mariocha
                  I have been waiting for such a licensing system.
                  Can we have more info ?
                  Is there a relase date in view ?
                  %(#008000)[Mario C.
                  • mariochaM Offline
                    mariocha
                    Any idea what is causing these (false) warnings to appear at every SU launch ?
                    I also get one for Curvizard, one for FredoTools, etc..
                    Everything is up to date.
                    %(#008000)[Mario C.
                    • fredo6F Offline
                      fredo6
                      Mariocha,
                      Do you have a 'slow' machine.
                      The best would be that you send me the Trace Log txt file (in Window > LibFredo6 Settings... > View Trace Log File. There is an export function.
                      Fredo
                      • fredo6F Offline
                        fredo6
                        Mariocha,
                        Souvenir is released, as part of Sketchucation Extension Store v3.1.
                        Is it to license your own plugin(s)?
                        Fredo
                        • fredo6F Offline
                          fredo6
                          By chance, did you migrate to High Sierra ?
                          • mariochaM Offline
                            mariocha
                            Yes, I did migrate.
                            That is the cause ?
                            %(#008000)[Mario C.
                            • mariochaM Offline
                              mariocha
                              Mariocha,
                              Fredo
                              I meant the licensing scheme.
                              Yes, for my own plugins. Did not find any info on this licensing.
                              %(#008000)[Mario C.
                              • fredo6F Offline
                                fredo6
                                @mariocha said:
                                Yes, I did migrate.
                                That is the cause ?
                                With slbaumgartner, we found the cause of the problem with High Sierra. As you may know, it comes with a new file system (APFS), which puts some mess in Sketchup, because now plugins are loaded in random order instead of alphabetic order.
                                I have prepared some fixes which are under tests.
                                Fredo
                                • fredo6F Offline
                                  fredo6
                                  NEW RELEASE: Souvenir v1.5a - 13 Nov 17
                                  Souvenir 1.5a is a major release:
                                  • Favorites, as a configurable list of links to files, folders and URL, which you can then launch in one click.
                                  • Bug fixing
                                  Souvenir 1.5a requires LibFredo6 8.0 or above
                                  See plugin home page of Souvenir for Download of Souvenir.
                                  Main Post of the Souvenir thread on this forum
                                  Fredo
                                  • fredo6F Offline
                                    fredo6
                                    NEW RELEASE: Souvenir v1.6a - 25 Feb 18
                                    Souvenir 1.6a is a maintenance release fixing bugs.
                                    Souvenir 1.6a requires LibFredo6 8.1 or above
                                    Fredo
                                      matt.gordon320
                                      Hello Fredo,
                                      Looking forward to trying this plugin and licensing system out. I do have a question before I try it out though. I use your "Additional Plugin Folders" to manage plugin distribution at my school and ensure all of our computers get updated versions of the plugins on a regular basis. Thus, I have two questions:
                                      1. The default Souvenir license is for 5 seats. Is it possible to get a higher seat allowance for the plugin, or would one need to obtain multiple licenses, and then how to install/manage those?
                                      2. Will this upcoming system work in a similar way to the limited seat count, and are there any other considerations to take? I'm like to ensure I can keep up with whatever changes in SCF licensing and still be able to manage plugins across multiple machines.
                                      Thanks,
                                      Matt
                                      • fredo6F Offline
                                        fredo6
                                        @matt.gordon320 said:
                                        Hello Fredo,
                                        1. Will this upcoming system work in a similar way to the limited seat count, and are there any other considerations to take? I'm like to ensure I can keep up with whatever changes in SCF licensing and still be able to manage plugins across multiple machines.
                                        Thanks,
                                        Matt
                                        Well, good question:
                                        1. SCFLicense requires installation on each device. Indeed the 'purchased' license file you got from Sketchucation can seat on a shared drive, but you need to create a local license on each PC: this is what is called License Validation.
                                        2. Souvenir license is FREE, so you can actually download the license several times so that you can have enough seats for your students.
                                        3. However, for other plugins where there is a commercial licensed distribution (like ClothWorks recently published by Anton_S), the number of seats does matter.
                                          For Schools, the answer could be to have a larger number of seats, as well as possibly free or discounted licenses.
                                        This is more a question that I will address to Sketchucation and which can be solved.
                                        As a final note, SCFLicense requires license installation on each PC only once. When a next version of the plugin or a next version of Sketchup comes, you do not need to revalidate. This, I guess, should ease your maintenance.
                                        Fredo
                                        • fredo6F Offline
                                          fredo6
                                          NEW RELEASE: Souvenir v1.8a - 19 Dec 18
                                          Souvenir 1.8a is a maintenance release fixing bugs.
                                          Souvenir 1.8a requires LibFredo6 8.7 or above
                                          • fredo6F Offline
                                            fredo6
                                            NEW RELEASE: Souvenir v1.8b - 02 Feb 19
                                            Souvenir 1.8b includes an indication of date and size for model files in the History dialog box
                                            Souvenir 1.8b requires LibFredo6 8.7 or above
                                            • 1 / 2
