    Construction plugin help
    extensions
    2 Posts 2 Posters 1.5k Views 2 Watching
    • K
      kattyk325
      Hello,
      I am wanting to recreate my house in SketchUp, and I am really wanting to create all the construction elements of the house as a part of that (I apologize, I don't know what all the technical terms are...hopefully someone could clue me in as to what term is used for what I am describing).
      Basically, I am wanting to make all the wood beams and boards and all the various wood pieces that make the structure of a house...I know there's a specific term for this, but I just can't figure it out πŸ˜†
      I know PlusSpec does this, but that's a bit expensive for me, and this is only a hobby, not for a job. I was wondering if folks on here could recommend a similar plugin/extension that would do the same thing, but less expensive?
      I attached an image of what I'm wanting the plugin to help me accomplish (rather than me trying to manually build every single part by myself).
      Hopefully someone can help!! Thanks so much for your time and assistance πŸ˜„
      Example
      Other Example
      • jujuJ
        juju
        Take a look at what "Medeek" (developer) is doing.
        You can also take a look at "House Builder" (plugin / extension) for the wall framing.
        "Profile Builder 2" (plugin / extension) is also a good choice for the wall framing, but you have to know what it is that you're making to get the best out of it.
