    Copy w/Base Point
    2 Posts 2 Posters 13.9k Views 2 Watching
    • dwgjunkieD Offline
      dwgjunkie
      I wish we could copy/clip with a base point - Ideally I would like to be able to (Windows) CTRL/C or CTRL/X with a base point.
      Is this a thing?
      Thanks, All!
      JL
      • mitcorbM Offline
        mitcorb
        In a way you can. Group the data you wish to copy. Ctrl x or c. Open the file into which you wish the group to be inserted. Ctrl V. Because it is grouped, it can be dropped, picked up again by another snap point and placed. This is a lot of circumlocution, for a simple process. I am assuming you are talking about the related technique used in Autocad, for instance. I use this quite often, as well as the Sketchup procedure I just described. Of course, there may be other variations.
