    HTMLDialog vs WebDialog?
    23 Posts 5 Posters 6.1k Views 5 Watching
    • Dan RathbunD Offline
      Dan Rathbun
      @medeek said:
      The error codes posted above.
      ... are occurring (according to your error messages,) in " medeek_roof_truss.rbs", line 5726, in callback method onLButtonDown.
      In the first you are calling a *() method upon an object that is referencing the global singleton nil object. Since the NilClass does not have an "asterisk" method, a NoMethodError is raised.
      The second method is caused by your code expecting a Float object, but getting a String object instead.
      The answer is simple. Whenever an object reference could reference disparate types (classes) of obejcts, use a combination of type validation and Ruby rescue clauses with the onLButtonDown callback method.
      I'm not here much anymore.
      • medeekM Offline
        medeek
        Okay 95% of that just went over my head, but I'll try and decipher into terms I can understand.
        But why would this error only be raised for SketchUp running on MacOS and not Windows?
        Nathaniel P. Wilkerson PE
        Medeek Engineering Inc
        design.medeek.com
          Dan Rathbun
          Basically I'm trying to prompt you to learn how to read Ruby error and backtrace messages.
          “filename:lineNo: inmethod”‘ or “filename:lineNo.”`
          http://ruby-doc.org/core-2.2.4/doc/syntax/exceptions_rdoc.html
          http://ruby-doc.org/core-2.2.4/Exception.html
          Data validation - Wikipedia
          (en.wikipedia.org)
          An example in Ruby of testing if an object reference is pointing at an object of a certain class:
          if obj.is_a?(NilClass)
          ... or ...
          if obj.is_a?(Float)
          An example in Ruby of validating that an object reference call responds to a certain method call:
          if obj.respond_to?(:methname)
          ... and testing for the "asterisk" method specifically:
          if obj.respond_to?(:*)
          I don't know (offhand) as I avoid Macs myself. (But OSX and MS Windows use different sets of keycodes.)
          Actually, looking at the backtraces (in your original error listing) the errors are kicked off by a LButtonDown keypress, but are occurring in the `` create_timber_geometry()`' method, lines 1064 and 1355.
          • 2 / 2
