    Contract CAD assistant needed - vectorworks and a bit of SU
    1 Posts 1 Posters 582 Views 1 Watching
    • U
      unearthed
      Hi All
      I need a part-time contract CAD assistant for my landscape architecture business. Ideally you will be a New Zealand Tax Resident, although this is not a prerequisite.
      Capability
      Vectorworks - I use VW Landmark 2008, but Fundamentals is all you should need; you just need to be able to save back to VW 2008 format. If you know any of Sketchup, BricsCAD, Autocad or MS Word/Excel that would be great. I often use the workflow where images/pdfs are produced via SU/LO and then referenced into VW.
      My CAD style is straightforward and focussed on producing plans to construct, plant and maintain landscapes. I also do some site assessment/court work.
      I typically carry out initial design in watercolour pencil and then take that to CAD to produce details. You would be supplied with annotated pencil drawings from which to work.
      I only use VW's 2D capability and when I want planting schedules I just use VW's worksheet.
      I do not use VW's plant database as have found it less than useful for custom projects.
      For labels I just use text blocks and manual keylines but if you are happy using key that would be fine.
      Where I want 3D I tend to use Sketchup Pro - 2008. I also do my cut and fill in SU using a plugin and then reference any graphics into VW.
      A new job may entail some/all of the following:
      • Site address supplied to you
      • Get data from https://data.linz.govt.nz/ and export as dwg or other if required (data may also be sought from Google Earth as well as a list of NZ urls that will be supplied where needed).
      • Import shp/dwg and imagery into VW
      • Produce linework / polys from supplied artwork
      • Make table and link to polys and calculate numbers from plant spacing and density data as supplied
      • Make up sheet set as per notes and template supplied and place tables on sheets
      Likely to be 5-10 hours/week.
      Example plans avail. on request
      Growplan - People ∩ Plants ∩ Place
      windows 7 64b, 4GB RAM, SU 8.0.16846
      Gimp, QGIS, Vectorworks 12, Bricscad 11
