    Display Section Planes - RESETTING
    3 Posts 2 Posters 547 Views 2 Watching
      Meph
      Hi just upgraded to 2017 pro from SU 8 pro.
      SITUATION:
      drawing with 4+ section planes. section planes are active depending on the scene.
      PROBLEM:
      using the section tool bar and clicking the button Display Section Planes - toggle section planes on and off will do exactly what is says, but it will no longer save my selection between scene navigation. When I click on a new scene my section planes are visible again even though I toggled them off. I have had this in the reverse as well. I can't have section planes stay visible when I switch between scenes. This is causing a nightmare for me when I print drawings and all the section planes are visible.
      (to add more clarity.. the section planes activate correctly and cut my drawings. The section plane "tool" lines and arrows are visible when I want them hidden or vice versa)
      Any help is greatly appreciated. Thank you.
        Meph
        https://www.dropbox.com/s/tzz4k6ropho08lq/Lacey%20Phase%202%20-%202017.skp%20-%20SketchUp%20Pro%202017%202017-06-23%2012_05_01%20PM.mp4?dl=0
        here is a link to a video i created displaying the problem
          alpro
          You have to update your scenes. If a section plane is visble when you create a scene it will remain visible in that seen even if you hide the section plane. You need to hide it and then update the scene.
